![]() Join Date: Sep 2006
I hate taking my truck to the shop.
I would rather do the work on my truck myself, but sometimes you have too. I needed the front end aligned. I took it down and they did it. Now for the fun part. About a week after maybe more it started drifting to the left, of course I had that look on my face like what now..
![]() When I was changing the idler arm I decided to grab the tie rod end on the right side and the guy forgot to tighten one of the clamps so they were rocking a bit. I just grabbed a few wrenches and did my thing. After changing the idler arm I drove it but not much differnt. Ok fast forward to today. When backing out of the garage it would clunk when I tapped the brakes so I stuck my head out the open door and notice the top of the tire moving in and out. I then grabbed my jack and prybar and poked around more. It happens the nut on the upper control arm came loose or something and all the shims fell out. I have to take it back to the shop and make them fix it. I am sure this doesn't happen all the time and I am sure they will make sure all is tight. What a PITA. ![]() Im not going to proof read this so I hope it makes sence... ![]()
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
1961 crewcab
Re: I hate taking my truck to the shop.
always gotta double check their work... which is a pita.
I lost a nice slotted mag to a tire shop once... they either didn't torque the bolts, or just plain did not tighten them... by the time I figured out what the noise was the inside of the wheel (mounting surface) was all chewed up....
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Good lord,, I can tell you stories of shops and what they didnt do.. gets me sick.. Its one of the main reasons I got back into a older truck I can work on without all the "Dealer Only" items..
I think one of the main reasons is about All Shops now pay there help piece work,, they get paid by the job spec in the book not by the hour... I had a 99 Cad STS that I drove away in only to find the whole Air box was still laying inside the engine compartment.. the guys never put the thing back together |
We have a great old school tire and suspension shop in my area, same guys have been there for years. A rarity I guess... the owner even has an all original '63 c10. Come to think of it, one of the mechanics has a vintage Challenger too.
I took my old truck to the shop and the service guy just said I should go somewhere else since these mechanics weren't even born yet when this truck came out. Experience is the key for older vehicles.
...just another truck junkie..
![]() Join Date: May 2009
I used to have a '71 C10 and last winter the starter gave out during a nasty cold snap. It was temps below zero and since I don't have a shop I tried taking it somewhere to have a starter put on. Keep in mind that I had the starter, just needed it installed. No kidding, no shop would even do that on the ol' girl. I ended up bundling up and doing it myself.
Mike "Bear" Shea |
I would suggest after all the re-work is done, have them set up on the lift with the tires in the air. Make sure you're there to double check all their work. It might piss them off but you're paying for this. This comes to a real safety issue where, God forbid, you have an accident. Also check for any missing cotter pins where they sometimes break off when removing, and some shops never replace. Good luck.
![]() '03 3500 Duramax dually '96 1500 ext. cab Chevy '66 swb C-10 '63 Panel '60 VW vert '56 VW vert |
#8 | |
GOD BLESS AMERICA! |
If the shop did such a sorry job the first time why would you give them another chance? Back when I was young early 1960,s My dad had a 283 truck that started burning oil. He worked away and was only home a few day a month so He took it to a shop to get a set of rings & bearings. Supposed to cost $150. When we went and picked it up and the bill was $210. told us the crank needed turned so it cost extra. So the truck ran poorly and still burned oil. We decided to check it out and turned out it had a flat cam one exhaust valve didn't open. a crankcase full of gas, Well we pulled the engine and for $125 bought a Sears rebuilt short block & with gaskets new lifters & new oil pump it came to $150. It was a 283 bored .060 that made it a 292 That was the very first engine I put together and installed. Well we found out that the engine had never been removed from the truck by the so called mechanic. So the crank obviously hadn't been turned. In fact the main bearings where the originals. We put the original engine in the truck bed and drove to the guys shop. He apparently seen us coming and hid out. We talked to his help and told them to have the guy contact us. The next week at school the guys daughter gave me a full refund check for $210. Never took anything to anyone ever again. I learned by trial & error to rebuild automatic transmissions just so I could do my own work. It seems trustworthy repair shops are as rare as hens teeth.
I am so lucky to have a shop that does excellent work and always charges a fair price for it. A friend of mines son started a shop in our town and has helped me many times on my Rods. He is the one that guided me on my S10 when I put in my 5.3 he also changed out the T350 for a 700R4 in the 64 when I needed it. He is a Full service and does alignments also. One thing that keeps me going to him is he races a Pro Mod Camaro, what a beauty!
Who Me?
Where I get my alignments done, I can actually stand over the guy doing it.. I have had to point out things before leaving and double check when I get home.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Buy an alignment tool and do it yourself. Super easy and you can get the settings you want. Even more important when lowered....
1936 Chevrolet 1/2t 1964 Chevrolet C10 1964 Chevrolet C10 (sons) 1965 Chevrolet K10 Suburban 1969 Chevrolet C10 1937 Plymouth P4 |
If you gotta watch them do it ? you just as well do it yourself. I never let anyone watch me work on anything. Years ago I was working in a truck shop. Changing the clutch on a cab over international. The owner operator came in the shop. I was under the truck and he came leaning over the frame rail blocking my light and knocking dirt down on me. I told him Westly Hardin one time shot & killed a man for sanding in the window & blocking the light. He moved and went and got a chair and came and sat down and kept asking stupid questions. I just quit and crawled out. We sat and talked for about two hours. Finally He stated when are you gonna work on my truck. I replied In working now your paying the hourly rate right now. So far you bothering me has cost you $50! He got mad and went into the office. the shop foreman brought him out into the shop and pointed to a sign that stated. Employees only. It boils down to this if you cannot trust someone to do the job correctly don't do business with them. And If you really want the job done to suit you do it yourself.
maybe in your case but many cranks have been turned in the vehicle - especially in that time period. i happen to have that equipment. strangely it's called the "in the blok crankshaft grinder" (from winona). i also have an "in the rod" boring tool (from winona). don't use them much anymore tho'
#15 |
hahaha - assuming he knew what you were talking about. i never had the luxury of getting paid by the hour so i just made sure that everywhere a customer was standing was where i was going next. then once, or twice, or more, i accidentally unloaded an air powered grease gun in their direction. these days you just point to the sign on the wall stating how your insurance co does not allow it. i HAVE (once so far) been busted by the insurance co when they made a spot inspection. almost got dropped.
#16 | |
#17 | |
#18 |
i was always strictly flat rate. one nice thing about that was we NEVER got any pay for diagnosis. sunsa*****es
and the flat rate wasn't very good. (GM) |
#19 | |
![]() Join Date: Oct 2007
#20 |
I did take it back and they did it under warrenty. A differnt tech did it this time and is seems to be pretty good. I will be checking every once in a while just to make sure everything stays tight.
#21 |
![]() Join Date: Apr 2009
I Worked Flatrate For 27 years and always Took Care of Customers from GM Dealer To Independent Shops To the Last 10 years As A Movie Studio Mechinc Building Cars For Fast And Furious And Others Movies, Always A Self Taught Wrench I Do it All.. Hate Hack Work... Do it Right The First Time!!!!!
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
#22 | |
![]() Join Date: Apr 2011
#23 |
They did fix the problem. God knows I will not go back, not even to buy tires.
#24 |
![]() Join Date: Nov 2007
I would rather get a root canal than do a brake job. Especially when it's cold. I don't have a heated shop. Every time I drive by this shop in lil ol Independence, Virginia right across the state line from my house. I see old stuff in there being worked on. I heard what I assumed was metal to metal when applying the brakes so I stopped in and asked the proprietor if he would do a brake job for me he was about what looked to be 80. He told me he was booked for a few days but if I could bring it back in two days time he would do it for me. I dropped it off on the agreed upon day. I left my phone number and asked him to call when it was done. A week went by, I was getting upset. I thought about it all day long yesterday and decided to go give him a piece of my mind. I walked in and saw him and asked him when my truck would be ready. He replied,"I was finished the day you brought it", I queried him as to why he did not call, he stated, "boy, when your my age you can't remember everything" and chuckled . He explained that I didn't need a brake job after all. A clip had come off the emergency brake causing the dragging sound I was hearing, and he fixed it. He also put a bulb in my dome light, and replaced the wiper blades because" they looked like they needed changing" (he was right, they were almost dry rotted) final bill $51.23. Guess where I will be going from now on for work I can't get to, or don't want to do? He could have done the brake job and charged me serious coinage if he was underhanded. I guess you can't do that in a a,mall town and survive in business, plus he is from a bygone era where honesty is paramount.
1963 Chevrolet C-10 "Ginger" ![]() 1970 C-30 Dump Truck "Scarlet" 2019 Chevy Silverado 2500 Z71 LTZ 1947 Indian Chief Roadmaster with Sidecar. 2012 Indian Chief Serial #002 of 110 built in '12 2016 Indian Chief Roadmaster |
#25 |
So I took my truck back on the 6th I believe. today I started hearing a noise out of the front left. Well now the upper rear shims fell out. I did catch it before I lost them, even the new bolt they put on was loose. I got out my bar and socket and made sure they were all tight because the right side was a bit loose also. I am going to recheck them in about a week or two depending on how much I drive it to see if they come loose again.
If they do then I will try red lock tight. I sure will call the tire company back and let them know. At least this time I tighten them and know they are tight. I should have checked that when I got it home but was just to darn lazy. I wanted to drive it.. ![]()
