Old 11-09-2014, 03:29 AM   #2101
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by zicc1835 View Post
looking good
Thanks, every day I seem to get a little closer to the light.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 11-10-2014, 02:29 AM   #2102
gdavis
gdavis's Avatar
Re: 1968
I got the gas tank sending unit coming in the mail tomorrow. I will install it and that job will be behind me. another job completed. TOMORROW or Tuesday
Check out Patches
Old 11-11-2014, 01:25 AM   #2103
gdavis
gdavis's Avatar
Re: 1968
Today, I worked on the firewall patch under the circuit panel box. It came out ok, not the best work I have done but ok. Mounted the fuse panel and ran a few wires to the rear of the truck. I have to put some wire protectors on the wires to the rear. I connected the tail lights and back up lights and used shirk tubing over the butt connectors as you can see in the pictures. I still have to connect the clearance lights on the rear before I put the wire protectors on them.
Check out Patches
Old 11-12-2014, 02:18 AM   #2104
gdavis
gdavis's Avatar
Re: 1968
Today, I finished with the rear of the truck except for the tag light. Waiting for the bumper before I can do that light. I attached the wire to the truck rail today and made some grounding block and a 12V block. To make the connections easier for the small stuff. As you can see in the pictures.
Check out Patches
Old 11-13-2014, 03:20 AM   #2105
gdavis
gdavis's Avatar
Re: 1968
Well done more wiring today. Got the front lights almost finished. I also got my new sending unit for the gas tank. A two line to replace the one line that came with the tank.
picture # 1 is the wire loom finished
picture # 2 is the wire for the engine compartment yet done.
picture # 3 is the new sending unit for the Camaro gas tank.
Check out Patches
Old 11-14-2014, 01:55 AM   #2106
gdavis
gdavis's Avatar
Re: 1968
today I pulled the gas tank back off the truck and replaced the sending unit with a two line sending unit. Made some rubber lines to fit the new sending unit. and done a little more on the wiring a slow process it is.
Check out Patches
Old 11-14-2014, 09:10 PM   #2107
swamp rat
swamp rat's Avatar
Re: 1968
Dang i havent recived any notifications in my in box for a long time, now i need to catch up, nice to know your making progress!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-15-2014, 02:01 AM   #2108
gdavis
gdavis's Avatar
Re: 1968
Thanks a lot. seen your seat it look good.
Check out Patches
Old 11-15-2014, 02:06 AM   #2109
gdavis
gdavis's Avatar
Re: 1968
Today I done some more on the wiring. It is coming alone real nice. I am starting on the safety switch/back up switch. Tracing the wire down isn't no fun.
Check out Patches
Old 11-15-2014, 02:09 AM   #2110
gdavis
gdavis's Avatar
Re: 1968
More pictures. As you can see I have a lot of extra circuits left over. I might use in the future
Check out Patches
Old 11-16-2014, 01:52 AM   #2111
gdavis
gdavis's Avatar
Re: 1968
worked on the alt wires today and got them buttoned up. Now I need the dash to be done. Maybe Monday I will have that. I hope.
Check out Patches
Old 11-16-2014, 02:15 AM   #2112
70LonghornCST
Moderator
70LonghornCST's Avatar
Re: 1968
Good progress. Keep it up!
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 11-16-2014, 10:13 PM   #2113
Number98
Prestige Worldwide
Number98's Avatar
Re: 1968
Its really coming together, looking good!
Number98 is offline   Reply With Quote
Old 11-17-2014, 01:49 AM   #2114
gdavis
gdavis's Avatar
Re: 1968
thanks number98 and Richard for you comments they are always welcome.George
Check out Patches
Old 11-17-2014, 01:51 AM   #2115
gdavis
gdavis's Avatar
Re: 1968
Tomorrow I have a friend that is coming over and helping with the wiring harness, I got the front and rear lights all connected. We will be working on the dash and switches. Wish us luck.
Check out Patches
Old 11-18-2014, 02:22 AM   #2116
gdavis
gdavis's Avatar
Re: 1968
Today A friend came over and we buttoned up the ing switch, wiper switch, head light switch, back up light switch and half of the wire that goes to the dash cluster. I hope to have them done in a day or two. Tomorrow I will solder wires together.
Check out Patches
Old 11-18-2014, 07:19 AM   #2117
Elliot949
Elliot949's Avatar
Re: 1968
Looks like you are cranking right along... Looks great...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 11-19-2014, 12:50 PM   #2118
gdavis
gdavis's Avatar
Re: 1968
started soldering up the connections and shorten the wires and cleaning up the rats nest under the dash. Got the dash all wired and looking good . too cold to work out side today. Last night it got down to 29. too cold for these old bones. I can be thankful that it doesn't snow here like up north.
Check out Patches
Old 11-20-2014, 02:53 AM   #2119
gdavis
gdavis's Avatar
Re: 1968
I got all the wiring done, I think. I will test the wiring in a day or two. I am getting a little discouraged. Sometimes I think I would be better off selling this project. But I guess I better hold on to it. I hope to order my rear bumper this week. Each week there seems to be something else I need.
Check out Patches
Old 11-20-2014, 07:47 AM   #2120
Elliot949
Elliot949's Avatar
Re: 1968
Man I get it... about the time we think we have it all figured out the truck throws another curve ball at ya... Keep the chin up... It really does look like you are on the downside of the hill... I am only half way up the hill... LOL
Old 11-20-2014, 09:50 AM   #2121
zicc1835
zicc1835's Avatar
Re: 1968
cold $ucks no snow here yet but too cold, too early, i know about them old bones .....you come a long way to let a little thing like 29 degrees to get you down take a look back thru your build .....you are getting real close to the finish line
zicc1835 is offline   Reply With Quote
Old 11-20-2014, 11:46 PM   #2122
colgad
colgad's Avatar
Re: 1968
George, did you get the dash panel plug figured out? I haven't had a chance to look into the differences in years. If you got it your the man!
You do seem bummed though, why the downer? Your truck is looking great! Your getting so close! It will a nice ride really soon.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 11-21-2014, 03:04 PM   #2123
swamp rat
swamp rat's Avatar
Re: 1968
George i'd so much like to be where your at now, way too close to give up!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-23-2014, 01:00 PM   #2124
Dean'smeanmachine
Dean'smeanmachine's Avatar
Re: 1968
that truck is looking great
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 11-23-2014, 06:30 PM   #2125
gdavis
gdavis's Avatar
Re: 1968
elliot949, zicc1835, colgad, swamprat, dean'smeanmachine, thanks for the comments. weather is changing and the old girl sits and the time to work on her is always taking the back seat. But one day I will have a driver. I went up state with a friend this week in and we drove his old truck. 1974 square body. was a pleasant trip, except for the rain all the time I was gone.
Check out Patches
