11-12-2014, 10:40 PM | #1 |
I'm trying....
Factory floor board markings
Eric uncovered this today when prepping the bottom of the passenger side floorboard.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
11-12-2014, 10:44 PM | #2 |
I'm trying....
Re: Factory floor board markings
I had a little trouble making heads or tails of it until I mirrored the image. Are these markings pre or post stamping? Any ideas on what it all means? It's a 1970 Blazer...do you think 69 is a date code? Just something I hadn't seen before. Any insight appreciated.
11-13-2014, 08:27 AM | #3 |
Looks to me like it might be material markings on the original roll of coiled steel (that the floor pan was made out of).
Do the markings repeat regularly along the length of material? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-13-2014, 09:04 AM | #4 |
I'm trying....
Nope, no other spots and no obvious repeats. That was my thought exactly, but wanted some informed insight. That kind of thing is super cool.
11-13-2014, 09:10 AM | #5 |
I'm trying....
Keith...you'd also be a great one to comment on this. I posted this pic in my build thread. It was under the dash pad. Is this truly from the dash pad manufacturer or something that just got caught under there at some time in the last 44 years?
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 11-13-2014 at 12:49 PM. |
11-13-2014, 10:51 AM | #6 |
Carpe manana
That's OEM from dash pad manufacturer. Did you find the carpet tag (pic from my K20)?
11-13-2014, 11:12 AM | #7 |
I'm trying....
Nah, no carpet in this base jewel. In retrospect I was lucky to have a dash and floorboard. The middle 30% of the body and the frame are about the only thing that's going to be left from the truck that rolled off the St. Louis line 44 years ago.
11-13-2014, 11:34 AM | #8 | |
K
11-14-2014, 09:54 AM | #9 |
Carpe manana
Here's a thread that shows some various factory marks:
http://67-72chevytrucks.com/vboard/s...d.php?t=591402
11-14-2014, 02:10 PM | #10 |
I found this on the front of my floor mat
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
11-17-2014, 04:35 PM | #11 |
Cool finds. Nothing much original in mine and was basically stripped when I Bought it.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
