Old 11-18-2014, 09:31 PM   #1
low&slow
C30 questions
From my understanding of searching the forum, a c30 cab is interchangable with a c10 cab with the exception of the rear cab mounts being slightly different. I was also told that the firewalls are slightly different as well.
Questions:
What are the differences on the interior for a c30 and a c10?
Are the dimmensions of a c30 cab the same as a c10 cab?
Does anyone have pictures of a firewall on a c30 cab?
Thanks in advance.
low&slow is offline   Reply With Quote
Old 11-18-2014, 09:41 PM   #2
71swb4x4
71swb4x4's Avatar
Re: C30 questions
As far as I know nothing is different. Not the rear cab mounts, and not the firewall. Now you get into different years, and you will find some slight differences.
You get into C40 and up cabs and you will see those differences, but not the C30 cabs.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-19-2014, 01:38 AM   #3
crazy longhorn
Fabricate till you "puke"
Re: C30 questions
20/30, are a different mount vs the 10 series....the rear cab cushions, are taller on the 20/30 series cabs. vs the 10 series cabs....pop the rivetets, on the 10 frame, * install the brackets for the 20/30 cab, as well as the mounts(rear)....good to go just for your info, the cabs are the same(10,30).....the mounts, will be the same(20/30)... mounts & brackets will be differernt , on the 10....longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
