I'm trying....
![]() Join Date: Oct 2013
Build Date Question
Hi guys,
I'm missing the door jam decal like the one pictured below(courtesy of 68panelman). I have no other original documentation other than the door VIN plate and SPID. My Blazer is a 1970 from St. Louis with a VIN ending in 1451XX. Is there anyway to determine the build month so that I can have this decal reproduced by ChipFlyer? Thanks in advance.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
Re: Build Date Question
I would also like to know if there is a way to tell or at least approximate the build date.
Subscribed |
Carpe manana
![]() ![]() Join Date: Dec 2010
No expert but I believe the VIN serial number if interpreted against other vehicles from the same plant that year with known dates would help narrow it down - but that's a big effort. Another approach would be to look for date codes on other items original to the truck. These (like date tags on seat belts, dash pad, carpet) won't give the exact month but together may help narrow the possibilities. Check on the back of the instrument cluster for a date code - I seem to recall seeing dates there but may be mistaken. Also, a date code from an engine block or carb original to the K5 would help narrow the choices. Are there date codes on the (original?) steering box or axles? Afraid you'll get close but not be able to nail it with certainty.
EDIT: check the cluster printed circuit for a date that gets you close
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 11-18-2014 at 04:36 AM. Reason: added |
I'm trying....
...Instrument Cluster! Great idea Pete. Otherwise, thinking right along with you. That's why I threw my VIN # out. I was hoping someone was going to chime in with a # close to mine.
My inspection tag under my dash pad said 12/22. Should I assume that means 12/22/69?...or is there another way to interpret it. There were no seat belts or floor covering. The original motor is gone. The quadrajet is from a 72. The front axle has been changed (thinking BOM #)...I don't know if the rear would be similarly trackable. C'mon you 70 St. Louis Blazer owners...I need you.
#5 | |
Keep in mind that is for the component part, so allow time for shipping and handling and that would place the timeframe for your truck build.... ....either right after the Christmas holiday or (more likely) after the first of the new year. January, 1970. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
I'm trying....
Ok guys...here's my cluster date--12/19/69. Of course I want you 70 Blazer guys to chime in with your VINs but, (and Keith you especially here) do you think January 1970 is the most likely build date...or could it have slipped into February?
The original engine block (assembly code) is your single strongest indicator of an assembly date on a vehicle. Basically everything bolted to it (like a carb) is assembeled at an earlier date. Interior parts have fairly long leads and some colors tend to be older stock than others.
Going off a cluster date might give you a close approximation, if it is the original cluster! At this point what is the point of trying to "reproduce" a number you cannot verify? If you must have a door sticker fine, just leave the date off. If you must "add" a date (at this point that is exactly what you are doing) I'd look for other vehicles to see what their build dates are and try to bracket yours tight. To do that you'd need to post a thread in all three sub-forums asking who has a Chevrolet VIN number close to yours, say 1000 units up and down, for the 70MY from St.Louis "S". Then you might get a result that will confirm your cluster date conclusion. To that end I have already checked through my SPIDs for a match and the closest I have is S148607. Unfortunately there isn't a member name or build date I can attribute to it. If you want to grab a number then 2/70 will probably work as I suspect early to mid-February is very close in your case.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 11-18-2014 at 03:21 PM. |
#8 | |
Remember there were far more Pickups built than Blazers along with other light duty truck models. So you need to look at everything that came down the assembly line with a xxxx0S1xxxxx VIN.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#9 | |
I'm trying....
I don't stray too much to the other forums unless I'm looking for parts, but that's good advice too. I'll post there as well and see if someone has one close to mine.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 11-18-2014 at 05:21 PM. |
Carpe manana
December 22, 1969 fell on a Monday so that's possible. The cluster date helps us exclude the first half of the year. January or February as stated seem likely. There was a GM worker strike that occurred in 1969 but I do no know how far reaching that was in terms of plant shutdowns or if would have impacted Blazer production (i.e. no K5s for first half of 1970 model year). A post soliciting serial #'s from 1970 K5s (don't forget Jimmys) built in January or February of that year may help. Sleuthing is fun.
Try scanning the K5 SPID thread for 1970 member trucks - may be a good place to start.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 11-18-2014 at 06:46 PM. Reason: added |
Again you need to look at all Chevrolet conventional light trucks to really nail down a day or week. This would included C10-30 and K10-20.
It should be easy enough to post clear requests (with a known build date or month) and see what comes up. But a Jimmy or any GMC isn't going to help due to a different sequence number range being used.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 11-18-2014 at 08:39 PM. |
Carpe manana
Interesting. To clarify - despite being produced at the same plant, the production serial #s differ between GMC and Chevy?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
These are created example VIN numbers for a St.Louise built Blazer and a Jimmy for the 1970 MY.
Chevrolet trucks (light duty) used this format KE180S100001 with the first 0 indicating the model year (1970) followed by the plant code S, then a sequence number starting at 100001. But with a GMC KE114-SZ50001 the S is the plant code and Z is the model year (1970) with the sequence number starting at 50001.
I'm trying....
Thanks again guys. I posted in the other forums. I'm not going to start another thread here, because I think anyone in this forum who might actually check their VIN has probably already read this and gets the idea...I hope.
...Just in case not...70 St. Louis Blazer guys, please check your ViNs and build dates for me. Thanks. About to go through the SPID thread now. You guys are the best.
#15 |
I'm trying....
I PM'd Zach, who posted the 148607 SPID on the truck thread that you referenced Tim. Hopefully he'll be able to tell us when it was built.
#16 |
The NP205 transfer case has a plate on the front with the exact build date of the case. I have found that it always matches the door jamb date.
1972 CST Blazer 350/350/205 tilt, ac, white with blue highlander plaid interior 1972 CST Jimmy 350/4speed/205 med red with black interior 1972 K20 Custom Deluxe 350/4speed/205 white/ochre/white/ochre 1972 CST Blazer 350/350/205 tach, ac, warn 5687 winch, light yellow with saddle interior 1972 CST Jimmy 350/4speed/205 dark olive with olive interior |
#17 | |
Normally there would be time associated with shipping, storage and moving the part lineside that would eat up several days, if not weeks (depending on physical distance between facilities, production volume, inventory on hand). Said differently, I would expect the date on alternators, a/c compressors, engines, transmissions, tcase, rear axle, HVAC modules, etc (any major component built up by an offsite supplier) to preceed the vehicle final assembly date by days/weeks/months. K
#18 |
I'm trying....
That would be awesome if that indeed works out. My transfer case is at the transmission shop along with the transmission. I'll try to swing by today and snap a pic. Thanks for the info.
#19 |
I'm trying....
Just got a PM from Steven who has a 1970 St. Louis Blazer with a serial # ending 1389XX with a build date of 12/69. Thanks for helping me close in on this guys.
#20 | |
Is the t-case a DD/MM/YY or DD/MM/YYYY format? Or is is simply a DD/MM as well?
#21 |
Kid's Mechanic
Knowing old Iron , there's only a 50% chance the transfer is as manufactured
#22 |
I'm trying....
Sorry guys I called the transmission shop and my transfer case has not be de-grossed yet. I cannot thank you all enough for your help and insight. One of the great things about this board, beyond being a huge information resource, is the generosity of spirit and supportive tone. No one had to click on this link and help me out...but I'm glad they did. I still don't know what month my truck was built but I'm getting closer thanks to you all.
#23 |
Carpe manana
Hijacking: can you run year-of-manufacture plates in Georgia?: http://www.chucksplates.com/?cp=&ss=Georgia
#24 | |
I'm trying....
#25 | |
I'm trying....
