11-06-2014, 11:52 AM | #51 |
Re: 72 K30 Build
And a couple more pics. I did sell all the take off do dads I wasn't going to use to a buddy that owns a car lot. Not much $$ but outta here.
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
11-08-2014, 04:28 PM | #52 |
Re: 72 K30 Build
So a few more things I noticed during demo. Looks like the truck had something happen to the trans. tunnel. Kind of ripped it up on the right side and popped the RF body mount free (high centered maybe?). It was the only mount that had been opened up to put a nut on the backside. Also looks like they may have put a floor shifter in it at some time? Don’t know both the manual trans. & transfer case linkage openings look factory from the underside.
11-08-2014, 05:03 PM | #53 |
Re: 72 K30 Build
The chassis shows a little luv also. It's got a busted u-bolt on the right rear and both lower rear shock mounts look like somebody gobbed on the welds. Thought we had gotten away without the frame being broke but found this one hiding by the fuel tank switching solenoid on the right rail. Pretty sure it’s fixable as this is very, very close to where it is going to be spliced anyway. So time will tell what is still hiding under the mud and yucka! Hopefully going start some initial mockup pretty soon! Would be nice to start building instead of blowing stuff apart..
11-14-2014, 01:47 AM | #54 |
Re: 72 K30 Build
Here's what's been happening..
11-15-2014, 10:17 PM | #55 |
Re: 72 K30 Build
Here is a few more mockup pics.
11-15-2014, 10:54 PM | #56 |
Re: 72 K30 Build
subscribed!! cool build, I'm gonna do a similar build but i'm starting with a 71 K20 frame and using a 80 dana 60 dually front end and a 77 cab and chassis 14 bolt rear and a 72 gmc c30 cab. haven't made up my mind if I'm gonna use the cab and chassis rear end or a dana 70 HD wide and make it a dually "pickup" Coop
1971 K20, Coop's beast (project) 1972 C30 wrecker, "Big Ernest" (SOLD) 1975 K5 Blazer (wife's toy) she got it in the divorce 2014 Street Glide Special 1983 K20 Big Block, auto (work horse) |
11-16-2014, 04:11 AM | #57 |
Re: 72 K30 Build
Looks good! wIsh i had your shop too!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-16-2014, 10:23 PM | #58 | |
Re: 72 K30 Build
Thanks Rat.. After building stuff outside in a carport and then later in a slightly oversized 1 level 2 car garage (spoiled us). We thought a 20x40 2 story job would be huge. It's not we just stuff more in it, not to mention the off site storage unit. Ha!
11-17-2014, 12:35 AM | #59 |
Re: 72 K30 Build
I'd be willing to bet that floor damage was from the front driveshaft coming loose at the transfercase and beating the hell out of the floor.
11-17-2014, 07:02 PM | #60 |
Re: 72 K30 Build
You know you are probably right 86454k30 good call. The front driveline has a sticker on it from a driveline shop in Texas.
11-18-2014, 09:21 PM | #61 |
6>8 Plugless........
Re: 72 K30 Build
Nice progress. The crack in the frame is nothing a grinder, welder, and a fish plae can't repair. The mock up is looking pretty good so far. That poor square body sure was used hard.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-19-2014, 01:15 AM | #62 |
Re: 72 K30 Build
Brett, I think its cool too, it's been done before many different ways. what I want it to build it like GM would have if they would have made one.
kinda like this but tougher looking. Coop
11-19-2014, 01:41 PM | #63 | |
Re: 72 K30 Build
Great minds Coop, I only have a couple of pics of trucks with fleetside beds in my 4x4 conversion folder (most are flatbed) and I swear one is the same truck you posted with different wheels. If I built one and I have thought about it, I prefer the narrower rear like the GMC below.
11-19-2014, 01:53 PM | #64 |
Re: 72 K30 Build
Really like the way everything is fitting so far a lot better than we originally thought (we will see if this holds true for the next phase of mockup). Check out the inner fender to frame contour, I like it and hopefully we can keep the body this low on the frame. Me and the miss’s are getting to be old farts so lower is better for us. Going to have to reposition all the mounts as expected.
11-19-2014, 01:59 PM | #65 |
Re: 72 K30 Build
We are also finding where we can remove the extra 31.5” out of the 164.5" wheel base (133” goal) looks very doable. 21ish here and 9.5ish there.
11-19-2014, 10:08 PM | #66 |
Re: 72 K30 Build
It looks like it will work out pretty nice. I really like the cab chassis DRW set ups with the tires tucked like that. I almost went that route with mine a couple times.
11-21-2014, 01:26 AM | #67 |
Re: 72 K30 Build
That's the big reason for going a 133" wheel base is that we have the option for a longhorn bed. I'll tell you though I love my flatbed for actually using the truck as a truck. My C30 is the first truck we have owned with a flatbed and I really like it a lot more than I thought I would.
11-21-2014, 01:35 AM | #68 |
Re: 72 K30 Build
It's hard to beat a flat bed for work. We're without one right now.
11-22-2014, 02:28 PM | #69 |
Re: 72 K30 Build
It's time to see if there is any room for a big block? Thought it would be quicker to swap tail housings rather than trannies for this step. Found the K3500 trans was not a virgin it has a 2wd truck output shaft, oh well it worked!
11-22-2014, 07:51 PM | #70 |
Re: 72 K30 Build
Speaking of flatbeds, did you scrap the bed that came on the square body?
11-23-2014, 12:09 AM | #71 |
Re: 72 K30 Build
Yup, I was going to give it to my nephew but he passed so it went to the scraper weeks ago.
11-25-2014, 01:05 PM | #72 |
Re: 72 K30 Build
So I was a bit worried the big block was going to be a problem because of the 4x4 engine set back. We want to use the RV Cheyenne Super/AC cab once the pass thru is repaired and making a lot of firewall mods would probably make running the factory air difficult. So minimal or no firewall mods is going to be the goal. In and bolted down and it looks great!
11-25-2014, 01:14 PM | #73 |
Re: 72 K30 Build
It is a little tight oil pan to the front crossmember. The right motor mount is loose/broken which may let it settle a little more than it would normally. Right now the oil pan is touching the diff breather hose and its hold down clamp that is attached to the crossmember. I'll reroute that hose a little later and see how it sits. We didn’t move the motor forward so oil pan to diff is not going to be an issue. Next step is going to be getting the cab back on my earlier marks and see what is going to happen with firewall clearance.
11-27-2014, 06:41 PM | #74 |
Re: 72 K30 Build
OK waiting on some turkey, so time to update the build thread with some more progress pics. I really like what I'm seeing, with the cab on my previous marks we have at least 1/2" clearance everywhere.
11-27-2014, 06:57 PM | #75 |
Re: 72 K30 Build
I don't think the cab could go any further forward without really lifting it off the frame. We'll have to check and see if a GM HEI is going to fit?
Tags |
72chevy, dually, flatbed, k30, motorhome |
