what to spray inside new wheel tubs ?
I got my new floor and wheel tubs done and was wondering what to use inside the wheel tubs and under floor to help with noise etc.Gravel guard,bedliner or ?.Is on a 78 blazer weekend driver.I will be using some sorta insulation on the inside of the blazer but thought if I have to paint the underneath I might as well use some extra sound deadening
Re: what to spray inside new wheel tubs ?
I've heard good things about Lizardskin for sound control on exterior surfaces. Sort of unrelated but I have heard of coating the undercarriage with WD40 prior to wheeling to make cleanup easier. It also helps keep road salt from building up.
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=511830 |
I know the pieces fit
Can you undercoat with lizard skin products? I thought they were designed to go on inside the tub.
#4 | |
http://www.lizardskin.com/off-road-v...nsulation.html " Since both coatings are tough and durable, they can be used as an undercoating to protect fenders and wheel wells from starring and denting from rocks kicked up from the tires. "
| Bookmarks |
