Old 11-20-2014, 09:38 AM   #1
j.rigby15r
j.rigby15r's Avatar
no dash lights
Alright so this might be a dumb question. But I'm finishing up my 64 and trying to fix electrical issues. I noticed I have no dash lights. My turn signals work kind of they don't flag flash but will turn on. Also the bright light indicator will come on but no back lighting. I checked the fuse panel and had no power to either side of the fuse. My dumb question is are the dash lights only on when the engine is on. My engine is not done yet so I can't check that. Also with my turn signals not blinking would that be in the turn signal cam, mine is broken and haven't ordered one yet?
j.rigby15r is offline   Reply With Quote
Old 11-21-2014, 12:47 AM   #2
FF SIX ONE
FF SIX ONE's Avatar
Re: no dash lights
Did you check the flasher on the blinkers. Or you might have a short on one of you wires. The dash lights usually go on with the head light switch. You should probably check your bulbs and your fuse.
FF SIX ONE is offline   Reply With Quote
Old 11-21-2014, 01:16 AM   #3
lowbuck
Re: no dash lights
Check your ground wire that’s what was wrong with mine.
lowbuck is offline   Reply With Quote
Old 11-21-2014, 01:21 AM   #4
j.rigby15r
j.rigby15r's Avatar
Re: no dash lights
On the fuse box the fuse labeled panel is not getting power on either side of the fuse. All the rest of the fuses are good.
Old 11-21-2014, 01:23 AM   #5
j.rigby15r
j.rigby15r's Avatar
Re: no dash lights
The light comes on just does not blink. What ground wire would it be? In the column or in the wire bundle?
Old 11-21-2014, 02:13 AM   #6
jtrichard
Re: no dash lights
make sure you have tail and brake light power....instr. power goes through that fuse then back to the head light switch rheostat then to the instr. fuse then to the dash lights
jtrichard is offline   Reply With Quote
Old 11-21-2014, 02:17 AM   #7
jtrichard
Re: no dash lights
are all the turn lights working? if you have a standard flasher (not heavy duty) if any blubs are not working/missing then it wont flash that is to tell you that you have a light out ......IS your hood off?
Old 11-21-2014, 03:09 AM   #8
j.rigby15r
j.rigby15r's Avatar
Re: no dash lights
Hood is on. I just finished re wiring my tail lights. My tail lights work. I don't know if the break lights do, they should since they are through the same wire. I will have to double check, but last I looked there wasn't even power to the panel fuse.
Old 11-21-2014, 11:33 PM   #9
FF SIX ONE
FF SIX ONE's Avatar
Re: no dash lights
Be sure to check all your bulbs to shore all the supplements are intact. You might have to chase those panel wires to make sure there's no breaks. Are the head lights turning on?
Old 11-22-2014, 12:35 AM   #10
ol_skool_chevy
ol_skool_chevy's Avatar
Re: no dash lights
Your head light switch in the dash may have given up. Move it side to side and see if they come on....if you buy a new one don't buy a cheap one...I did that and ended up buying 4 before learning my lesson.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 11-23-2014, 12:26 PM   #11
rudyyloverboiii
Re: no dash lights
My under the dash wires started smokijg yesterday
rudyyloverboiii is offline   Reply With Quote
Old 11-23-2014, 09:28 PM   #12
j.rigby15r
j.rigby15r's Avatar
Re: no dash lights
So check this. I went to get some gas and drove over some bumps and now my dash lights work. None of the gauges and still have turn signal issues but I now have dash lights.
Old 11-23-2014, 09:31 PM   #13
j.rigby15r
j.rigby15r's Avatar
Re: no dash lights
The indicator lights come on, sometimes one side sometimes both at the same time. But no blinking.
Old 11-24-2014, 03:33 PM   #14
FF SIX ONE
FF SIX ONE's Avatar
Re: no dash lights
so check this. I went to get some gas and drove over some bumps and now my dash lights work. None of the gauges and still have turn signal issues but i now have dash lights.
There must be a bad wire contact somewhere or a bad wire. Try cleaning out all the wire plugs and look through all your wires for any kind of damage. You might also want to check the fuse pronges on the fuse box to make sure they are not loose.
Old 11-24-2014, 03:42 PM   #15
FF SIX ONE
FF SIX ONE's Avatar
Re: no dash lights
You're probably grounding out a hot wire somewhere? My right tail light wire got caught between the frame and the bed somehow, then did the same thing as yours.
Old 11-24-2014, 08:32 PM   #16
rudyyloverboiii
Re: no dash lights
thats probably right since i had a lot of excess wires on my alternator/generator that the previous owner did to rig it
Old 11-24-2014, 08:43 PM   #17
j.rigby15r
j.rigby15r's Avatar
Re: no dash lights
I have all new wires from the firewall back. I think it's in the colum. When I replaced the turn signal cam I noticed the metal pieces under the cam were messed up and a piece feel out. I've tried finding a new one but no luck so far.
Old 11-24-2014, 10:23 PM   #18
jtrichard
Re: no dash lights
$66.00 http://www.ebay.com/itm/1964-1966-Ch...6a93ef&vxp=mtr
Old 11-25-2014, 10:26 AM   #19
j.rigby15r
j.rigby15r's Avatar
Re: no dash lights
Originally Posted by jtrichard View Post
Thanks for the link. I got one on order. Hopefully it is what the problem is and I didn't waist $60 for nothing.
Old 11-30-2014, 02:21 PM   #20
j.rigby15r
j.rigby15r's Avatar
Re: no dash lights
So I've somewhat installed the new turn signal switch. The turn signals now come on and stay on and on the right side. But still no blinking. They come on solid. So I've been told that all lights have to work in order for them to flash. All for signals work and so do the running lights. I don't think my break lights do. So I'm going to check and see if that's my issue. Does the stop switch control the break lights?
