Old 11-20-2014, 09:29 PM   #1
jfw432
Gauge swap questions
It seems like this issue has been covered 10 million times for stock idiot lights to stock gauges or idiot lights with expensive wiring harness and aftermarket gauges. However, after 2 weeks of searching, I've yet to find anything regarding the sending unit.
Are the sending units the same regardless of the gauge cluster or will they have to be changed? I don't see any issues installing a tach or voltmeter. Will oil pressure and water temperature require new sending units?
jfw432 is offline   Reply With Quote
Old 11-20-2014, 11:09 PM   #2
Sodak
Active Member
Re: Gauge swap questions
from what i was told yes.
Sodak is offline   Reply With Quote
Old 11-20-2014, 11:31 PM   #3
jfw432
Yes the sending units are the same or yes they need changing?
Old 11-20-2014, 11:50 PM   #4
Joe Pass
Joe Pass's Avatar
Idiot light sending units are just a switch, they illuminate a warning light when the set reading is reached like "hot'. The sending unit for gages work a variable ground to vary the gage reading...In a nut shell the units are different and you will need the "gage" type for your new gages
Joe Pass is offline   Reply With Quote
Old 11-21-2014, 08:03 AM   #5
jfw432
Ok thanks
Old 11-21-2014, 09:47 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
I swapped the idiots to gauges/Tach in my 78
yes they need to change sensors as well as move wires in the plug.
or you will make a short
I used these
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
