84 c10 Rochester 2 barrel off idle stumble
Hey guys,
Just picked up a clean rust free 84 c10 that originally came with a 6cyl but was swapped over to a crate GM 350. The swap is clean and looks like it was done some time ago. Anyway, it has a 2 barrel Rochester carb on it. I would love to just rip it off an replace it with a 4 barrel but for now I'd rather drive it as is. The problem I'm having is an off idle stumble, only under load. I hooked up a vacuum gauge and adjusted both mixture screws properly. I also had to reroute the vacuum lines as they were improperly hooked up. I thought I had the problem solved after doing these two things, but no luck. One thing I didn't do was check timing because I don't have a timing light. Also I don't have a tach hooked up. Any ideas? I have a 5" autometer tach laying around I might temporarily connect and I'll buy a timing light, but I'm thinking I'll need to rebuild the carb. Also my kick down for the th350 trans doesn't do anything. Help is appreciated. Cheers! ![]()
1984 C10 swb 1985 K20 longbed 4spd 1977 K10 longbed -SOLD 1962 Chevrolet C10 swb 6cyl. 3spd. -SOLD Last edited by Triple6Goat; 11-23-2014 at 07:11 PM. |
