Rockers1/2"off the ground
Does not need to be constantly oiled like some a/c compressors? It is already oiled and sealed? And also york compressors do not need any check valves or whatever that only the air allow to flow in one direction?? The compressor it self will withstand how much PSI? Basically i am asking if i can just put the compressor on without any extras i have to put on? I want to run and keep about 150 PSI in my tank. thanks.
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca |
Trucker.
You do need a check valve($8 max) and it is self oiled but you still have to check the oil in it about every 2 weeks. You'll also need a blow off valve as well as a pressure switch and a braided stainless leader hose. The heat is too hot off the manifold on the comp to use a regular air hose.
OK cool thanks.
#4 | |
Trucker.
You still need a pressure switch otherwise you're gonna over fill your tanks depending on the pressure they're rated at.
Try spinnin 4 rear tars
Get a pressure switch and a blow-off valve. Then you don't have to worry about overfilling your tanks. Of course you could put the toggle switch on there, but wire it in with the other two, just to be safe!
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
Ok i now have a york a/c compressor
Can't kick the addiction!
Here is a very helpful site to visit regarding york compressors and everything needed to do an onboard air system.
Here is the site:http://www.onboardair.com |
Progress = 0%
York info....
Kilby Enterprises Oil change info (taken from above link).... http://www.onboardair.com/pdf/9.pdf
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
WOOHOO!! Thanks guys!
Out draggin'
DEFINITELY hook up a toggle inline to kill the power AND A PRESSURE GUAGE THAT GOES TO 300 PSI. My pressure switch went on me & I didn't realize how much PSI was in the tank after the truck was idling for almost 10 minutes. Well, I hit the all up switch(fullsize extended cab longbed GMC with a cap on back) and sent the front of the truck about 18" in the air and the rear well over 24" with one tap. Needless to say I actually buckled the top plate on one of my 2600#bags and broke the mount on the frame for the same bag. Not a good night. Looked cool as shiznit in the air but I paid the price. Keep in mind these things are capable of putting out 300+ PSI.
91 GMC Xcab LB-Bags/bd/caddy clip SOLD 72 C10 Cheyenne Super LWB SOLD 92 GMC K1500 Burb 72 C10 Burb (ex. Cheesewagon)SOLD 72 C20 Burb parts truck 71 C10 Burb "project" |
