Rebuild or just reseal trans and t-case while out for clutch
So my truck is a 70 GMC K2500. Stock 350, SM465, NP205. Less than 90,000 original miles. This spring I need to replace the clutch but other than that everything shifts perfectly fine without any weird / worn bearing noises. I do have plenty of leaks though since it is all 44 years old...
While I have everything out for the clutch should I go ahead and rebuild the trans and transfer case or just put new seals and gaskets in? What would you do? Should I be fine, bearing wise, until it's next clutch job? Any suggestions on a clutch (I'm thinking NAPA) or tips for pulling everything out? I will probably pull the engine too so it can get some new gaskets, maybe a cam too Thanks ahead of time!
![]() 70 GMC K2500 82 GMC K3500 09 GMC 2500HD 4x4 |
Re: Rebuild or just reseal trans and t-case while out for clutch
I had my T-case resealed, they do have to partially dissasemble, i just asked them to look for anything bad and they said it was fine.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
That's kind of what I'm thinking as long as everything looks and feels pretty good once it is opened up. Thanks!
