Closed Thread
Old 11-24-2014, 03:06 AM   #1401
Gravityamp
Gravityamp's Avatar
Re: What did you do to your truck today? Chapter II
That is way cool .
nice work
Peace
Gravityamp is offline
Old 11-24-2014, 05:16 AM   #1402
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: What did you do to your truck today? Chapter II
Got both new seats mounted and wired tonight. The six way, lumbar and heaters all work. I wired the heaters so that if the switch is left on and you unbuckle the seat belt they will automatically cutoff.
https://www.youtube.com/watch?v=WKgJ1P_h69Q
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 11-24-2014, 10:37 AM   #1403
KMC3420
KMC3420's Avatar
Got my frame back on the ground. Had 2 flat tires previously, so technically it would not roll anywhere. Sorry for the cell phone pics.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline
Old 11-24-2014, 12:32 PM   #1404
Redline novdog
Redline novdog's Avatar
Size:  56.7 KBafter a couple attempts at sanding polishing the turbine/hurricane/? rims I decided to powder coat chrome with black recess between the fins. Got the chrome on. Now I need to clear coat and then tape and put the black p/coat on.
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline
Old 11-24-2014, 05:55 PM   #1405
CST10
CST10's Avatar
Changed the pushrod cover gaskets and valve cover gasket yesterday. Today I cahnged the oil pressure sensor. Now no oil leaks, yea.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 11-24-2014, 09:08 PM   #1406
colgad
colgad's Avatar
C50 new springs and supplemental air bags and bowtie installed.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 11-24-2014, 10:21 PM   #1407
Tinkermc
Well I hate to admit it but it was 77 here today so all I did was drive it. Wed high may be as high as 40 with snow likely.
Tinkermc is offline
Old 11-25-2014, 06:26 PM   #1408
R.L.
R.L.'s Avatar
Finally tightened the throttle return spring and discovered a fuel leak, fixed it bet that improves my MPG. and it's so cool to have my engine RPMs drop down to it's base idle between shifts.
R.L. is offline
Old 11-25-2014, 09:06 PM   #1409
mechanic350
mechanic350's Avatar
well i put my steering wheel back on after i pulled it off while backing into my garage. so that was a scary experience.
1972 Chevrolet swb fleet side. - SOLD
2018 Toyota Tacoma but hunting for another C10
Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303
Instagram: https://www.instagram.com/72c10shortbox/?hl=en
mechanic350 is offline
Old 11-25-2014, 09:25 PM   #1410
jscs94
Bought a painless wiring harness kit for my '71 GMC.
jscs94 is offline
Old 11-25-2014, 11:30 PM   #1411
CST10
CST10's Avatar
Just put a 3/5 drop on ol Owen tonight. No pictures yet as its dark outside. I will post some tomorrow.
MyToys:
CST10 is offline
Old 11-29-2014, 03:54 PM   #1412
allchevy58
allchevy58's Avatar
Replaced turn signal switch due to Hazard button broke. Replaced with original style red button.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline
Old 11-29-2014, 06:28 PM   #1413
MoFormula
Bought an AAW wire harness from MCB Matt. I'm about to see how deep the water is and if I can swim. LOL!
MoFormula is offline
Old 11-29-2014, 09:17 PM   #1414
Kungfoogrip
Kungfoogrip's Avatar
MoFormula...I am right there with ya brother I started on mine today. Took the seat out, tore the dash down, took thresholds off and took the tires off and put the truck on jack stands. Waiting on my crimpers from AAW and my wire looms this week..should get rolling by Friday evening!
Kungfoogrip is offline
Old 11-29-2014, 09:29 PM   #1415
Possmguts
Possmguts's Avatar
Started grinding away some bad body work.... just getting started on a complete tear down and frame off and started a new build thread. Wish me luck.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 11-30-2014, 12:58 AM   #1416
BlacklandCamper
Placed my order with LMC for a new gas tank, sending unit, filler neck grommet, and turn signal lever. Got the jitters pulling the trigger on what has been my biggest expenditure on this truck so far. Went ahead and topped it off with a new fuel pump, hard line, and a few tools to make everything happen. To make things sweeter, I had one of my regular customers donate a pair of HD coil over rear shocks that he had taken off a 72 K20. They should go nicely on Grunt.
Hoping to have almost everything together enough to start driving him to work on a regular basis within the next week or two. Thank goodness I live in a small town, the cops know me, and know that my truck used to be driven by the guy who used to service their cruisers. That should let me drive him around my town without to much trouble.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline
Old 11-30-2014, 01:15 PM   #1417
getsomegreen
Originally Posted by colgad View Post
Finally on the last leg of painting the 67. Got the bed assembled this week and Painted today!!!
Only the hood is left.
How long did your build take?
getsomegreen is offline
Old 11-30-2014, 08:57 PM   #1418
Lou Boffa
Lou Boffa's Avatar
Installed new 15" Grant steering wheel. I do like the extra room! Also changed oil/filter--one of my favorite things to do on a crisp fall day in S Texas.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline
Old 11-30-2014, 09:08 PM   #1419
R.L.
R.L.'s Avatar
Upgraded to the best pair of shocks Monroe offered for a smooth ride, did some wiring work. My heater fan wasn't working. Installed a new steering gear box. Hope to have time to drive it some tomorrow, I'm tired and hungry this evening.
R.L. is offline
Old 12-01-2014, 11:02 AM   #1420
73737373
On my 70 CST, removed rear coil springs, replaced trailing arm, pulled and replaced a long bed passenger side, ground off some rust on the frame. Didn't make a ton of progress, but had beautiful weather to work outdoors; very therapeutic.
73737373 is offline
Old 12-01-2014, 07:00 PM   #1421
R.L.
R.L.'s Avatar
Finally my pittman arm came in, installed it and took her for a spin, with those new shocks and that new steering gear box it's a new truck, just a sweet old ride. Just what I wanted.
R.L. is offline
Old 12-01-2014, 09:14 PM   #1422
Bravojmc
Out with the old in with the new. Almost ready to blast.
[IMG][/IMG]
Also Mocked up the bags to drill the holes and hole sawed holes for my air fittings.
[IMG][/IMG]
Bravojmc is offline
Old 12-01-2014, 11:06 PM   #1423
Lees68GMC
Lees68GMC's Avatar
New Wheels Boss 338s 8.5 X 20 front with 255-45-ZR20 Falken Azenis 453 and 10 X 20 Rears with 295-40-ZR20 Falkens
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline
Old 12-01-2014, 11:32 PM   #1424
BlacklandCamper
Got the new fuel pump in, along with the new alternator bracket, now it moves fuel, and the belt doesn't squeal. Half way through getting the turn signal switch replaced, and still need to get a few other things done. Hopefully tomorrow.
Old 12-01-2014, 11:32 PM   #1425
slowcpe
slowcpe's Avatar
Finally started tearing my truck down for new suspension and drivetrain. Pretty excited
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline
Closed Thread
