Old 01-23-2004, 02:04 AM   #1
krazy_texan
krazy_texan's Avatar
pros and cons of front drums
ok guys lets here em i have not ever dealt with front drums so i want to know as much about them as i can
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 01-23-2004, 02:23 AM   #2
Alvin
Never Done?
Alvin's Avatar
Pros? I can't think of one. The only thing I can think of is if you're going for a bone-stock restoration. Beyond that, I can't think of anything.
Cons, six lug pattern limits wheel selection, they don't dissipate heat as well as discs do, and in my preference discs just plain look better. The way I see it, there's a reason most cars (and trucks anymore) come with four wheel discs.
Anybody else got some ideas?
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 01-23-2004, 02:26 AM   #3
68CST327
Pro: They weigh less than most disc setups.
You can also buy kevlar shoes for the drums which supposedly kick the crap out of regular discs (assuming you have power drums).
68CST327 is offline   Reply With Quote
Old 01-23-2004, 02:51 AM   #4
1969 GMC
1969 GMC's Avatar
another pro: since almost everyone gets rid of them, it should be easy to find components if they haven't been sold for scrap.
con (more for the off roading crowd): drums can pack with mud, greatly reducing braking capacity.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-23-2004, 02:56 AM   #5
68 Suburban
68 Suburban's Avatar
Here are a few links that might help you:
http://forums.vmag.com/suvsuburban02...ages/1382.html
http://forums.vmag.com/suvsuburban02...ages/1380.html
68 Suburban is offline   Reply With Quote
Old 01-23-2004, 03:04 AM   #6
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Pros: "If you guys can think of any other than ease of parts, tell me" OOOO OOOO Front and rear parts are the same
Cons: Harder to stop, and even HARDER when they get wet . Have to bust drum off to get to shoes/ect (and my fronts ones are stuck!!! I had to pull the whole hub on both front of mine)
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 01-23-2004, 03:30 AM   #7
gonebad2
Merciless Butcher
gonebad2's Avatar
Con: If they get really wet, they can damn near kill you in a hard stop situation. Trucks were even worse because they usually didn't have power steering or power brakes. Nothing quite like taking a hard unplanned left turn into oncoming traffic with drenched front drums. Most of the older guys on this site know exactly what I'm talkin about. If you ever get the chance to take a drive in a 30's or 40's stock truck it can be a real eye opener.They used mechanical brakes up until 1937 or 1938( I think, for F*rd..Not sure about GM), you could also jackknife the front wheels due to poor or broken steering stops. Most front suspensions were very lightweight for a truck. I sure do like the modern age.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 01-23-2004, 04:16 AM   #8
Injected68LS1
Injected68LS1's Avatar
Pros: none, I have discs now
Cons: I had power drums for too long. I hated working on them.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 01-23-2004, 05:56 AM   #9
PR454SS
PR454SS's Avatar
One more Pro: less resistance for drag racing!
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 01-23-2004, 10:17 AM   #10
67dragtruck
67dragtruck's Avatar
drums
The other con that I didn't see mentioned is that they get hot in stop and go situations and don't work nearly as well when hot.
Tom
67dragtruck is offline   Reply With Quote
Old 01-23-2004, 10:17 AM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
They should be rivited onto the hub.
Old 01-23-2004, 12:50 PM   #12
Injected68LS1
Your right to a point. All drag cars that I know have disc brakes. The secret is that they don't run any residual pressure valves. This allows the pads to back away from the disc and cause no drag at all. It works even better if the master is below the floor.
Later
Old 01-23-2004, 01:37 PM   #13
SWEET7T
SWEET7T's Avatar
So you have to replace the whole shabang when the time comes?! I was sure that the drum came off just like on the rears...
There goes my idea of swapping larger drums onto the front (pg 62 March '03 Classic Trucks). Since the front and rears are the same size, I thought that I might be able to fit them onto the front, but since it is all one piece...
SWEET7T
Old 01-23-2004, 05:06 PM   #14
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I thought of another Pro: No brake dust on your front wheels with drums.
I have drums on most of my vehicles but im used to them. Their "cons" don't really bother me. I keep them clean, adjusted and in top working order so I don't have any trouble.
Discs do have alot of advantages but im from the old school I guess. I wouldn't turn down any free disc brake setups though.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 01-23-2004, 05:18 PM   #15
redjp4x4
I've seen a few conversion kits and read a write up on homemade conversion, how hard is it to do the conversion, and is it really worth the money and time spent?
Tony
redjp4x4 is offline   Reply With Quote
Old 01-23-2004, 09:15 PM   #16
Pilgrim
My 69 C10 shortbed had drums. My 72 C10 had discs. My 71 burb had discs. My 68 C20 camper special has drums. kept them all adjusted and had no problems. I make a practice to drive safely and keep ot of lakes. You believe that, right? :
I think it is more a personal choice.
Bob
68 C20 Camper Special
Pilgrim is offline   Reply With Quote
Old 01-23-2004, 09:38 PM   #17
Blue Beard
Blue Beard's Avatar
I have drums on mine with only one regret.........their not 5 lug.............
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-24-2004, 01:13 AM   #18
Longhorn Man
Nope... just drill out the rivits.
