what to do?
I have a 1971 K series 3/4 ton 4x4 PU, great running, great drivetrain. Frame is fair- but usable. Cab is rough underneath. Love the truck, lot of work to fix the cab. I found a 1968 1/2 ton 2 WD, with a freshly sandblasted frame, very solid cab, no drivetrain . They are asking 3 grand for that one. The dilemma? IS it better to buy the 68 and take what i can from mine off, definitely want to keep as a 4x4, or try to just buy the cab from the 68? Not sure if I can use the axles from the k20, and if i can do I have to weld shackles on the 68 frame to accept the front leafs from the 71?? Looking for some knowledge/advice. Thanks.
Just like to part out trucks!!
Re: what to do?
way too much work IMO to make the 2wd a 4x4. Find a good body and put it on your 4x4 frame
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
Old member
Agree much easier to find a cab than swapping. if I'm remembering correctly
2 wheel motor mounts are differant also from a 4by4. The stock ramhorns are differant also. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
