Old 11-25-2014, 01:19 PM   #1
az1970k5
az1970k5's Avatar
Identify the steering column question
I have a chance to purchase this tilt for my 1970 blazer. The seller says its from a 1972 c10. I noticed the hazard knob looks like a later model. Im a newbie so any help would be greatly appreciated. Thank you
az1970k5 is offline   Reply With Quote
Old 11-27-2014, 01:15 AM   #2
Chulisohombre
Chulisohombre's Avatar
Re: Identify the steering column question
The knobs look like my 72s. But I don't have tilt or auto indicator up top. The plug looks like mine but I had switched out a earlier wire harness so mine has a conversions n plug between the harness. Double check that the plug and connectors fit yours before you buy. Should b able to Measure where it connects and make sure it's right.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
