![]() Join Date: Feb 2011
Help itemizing Electrical Components for my 67 C10
I need help itemize my electrical components for 1967 C10. I currently have my Painless Harness, Dakota Digital Dash with it's components, My outside lights, electric fan relay, fuel sending unit, my main thing is all the switch items, like the switches that go to the dash, the brake light switch that goes on the brake pedal, and etc. My truck was gutted by the PO and I need everything. I also want to go with remote locks, alarm, a vintage radio with blue tooth capabilities, After market AC unit, and I've decided to go with a push button start. I really would like to start with the switches. Anyone got an itemize list and the best vendor on quality electrical parts?
http://67-72chevytrucks.com/vboard/s...ban+Retro:fro: Last edited by Orangetonicclicc; 11-26-2014 at 03:38 AM. Reason: More details |
![]() Join Date: Sep 2007
Re: Help itemizing Electrical Components for my 67 C10
Headlight switch is different for a 67 than the 68-72. The harness has an extra wire. Either purple or brown i believe. Then the wiper switch ive been told is one year only as well. Brake light switch, heater motor switch. No door switches as they werent used in our trucks in 67. Best bet for the door locks and windows is aftermaket parts that your painless harness should supply power directly to.
1967custom |
#3 | |
So get the 67 Headlight switch. I'm buying an after market AC unit, so do I still Ned to buy a heater motor switch? I want to keep my windows manual and only have my locks remote for an alarm. I've been researching everything I need, so based on your advice, it seems as if I was on the right page. I'm going to have to get a windshield washer motor and a foot dim switch as well. Lights for the glove box and underneath my hood as well.
http://67-72chevytrucks.com/vboard/s...ban+Retro:fro: |
Old member
Aftermarket AC/heater kits should have one switch only for both. Under hood lights just buy the mecury ones that come on when lifted. Head light, wipers, ac/heater radio is switched but internal.
Brake switch neutral safety switchs under dash. Horn, turnsignals. Door locks you can buy the kit that works both doors from a key fob are the key are the door lock itself. This is the one I was looking at on LMC truck website. Bottom left for 2 doors. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
| Bookmarks |
| Tags |
| electrical, electronics, relays, switches, wiring |
