Re: 1971 C30 time to get started...
The "Load Bolt" as it is commonly known, bears against a shoe/thrust pad to control ring gear deflection under load. It is set with a static clearance of 0.005-0.007". Here is the clip from the factory overhaul manual on the proceedure.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#2 | |
Thanks Tim. Great info and getting info to track down new pad and will replace and readjust it. Jra
1971 C30 Dually dump "Lil' Blue Truck" 2005 Silverado LT 2500HD 4X4 Duramax "Lil'Red" 2013 Sierra SLT 2500HD 4X4 Duramax "Big Red" |
