Old 11-27-2014, 03:07 PM   #1
WiggyHD
Re: 68 S/C update.....
Originally Posted by Hart_Rod View Post
My new Ridetech HQ shocks showed up today OBTW, a BIG THANKS to board member Crawdadfox for getting my order shipped quickly, .
Were they Part #: 22189841 (rear) and Part #: 22149841 (front)? I didn't see anything pertaining to a different part number for a lowered truck.
Thanks!
Mark
Retired Air Force/Disabled Vet
1969 Chevy C-10, On the way to greatness!
WiggyHD is offline   Reply With Quote
Old 11-27-2014, 06:03 PM   #2
Hart_Rod
Hart_Rod's Avatar
Thanks!
Mark
Mark - measured the difference between mounting points on my front and rear shocks and then called Ridetech. They recommend the shock number that I should buy base off of those measurements.
On a different note, I changed out the axles hoping that the rear vibration/hop would go away but it didn't.... So I got to looking at the rotor/axle hub where the rear wheel bolts on and you can see where the wheel isn't bolting on centered. I think the CPP rotor is so thick that very little of the hub area is sticking out past the rotor, so the wheel is not centering up on the wheel flange. I have the cone style lugnuts but they are not forcing the wheel to center up, which is causing the rear to bounce. . Not really sure what to do now....
Hart_Rod is offline   Reply With Quote
Old 11-28-2014, 10:11 AM   #3
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
I actually read an post somewhere that said one of the axle tubes had tweaked under load and caused this same symptoms... This was a 1000hp truck... but who knows what it would actually take to tweak one...
Just a thought... I will see if I can find the post...
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 11-28-2014, 10:29 AM   #4
Hart_Rod
Hart_Rod's Avatar
I don't believe it's an axle tube. This problem started when I rebuilt the rearend and added the rear CPP disc brakes. I had these wheels on with drum brakes and had no such problem. I'm pretty sure it's due to the fact that the wheels aren't centering up on the hub when I bolt them on. I'm going to pull a rotor off and bolt the wheel on and see if I still have the same problem.
Old 11-28-2014, 11:01 AM   #5
chevyguy_72
Vintage Evil
Yeah I could see that being an issue as well...
Current Rides:
