Old 11-23-2014, 04:23 PM   #1
tiddlar
i want to widen rear fenders
i want to add 5 inches to my rear fenders. I've talked to a lot of gentlemen and a lot have said to cut down the middle and add the metal. the guy who will be doing this for me said he would widen from where it attaches to the bed. what are your thoughts on this? would it be better to widen from the center or to where it attaches to the bed?
tiddlar is offline   Reply With Quote
Old 11-23-2014, 04:59 PM   #2
T Hilde
Re: i want to widen rear fenders
Which fenders? 47-55.1, by the mounting edge or 55.2-59, either way.
T Hilde is offline   Reply With Quote
Old 11-23-2014, 05:03 PM   #3
tiddlar
I have. 53 Chevy. So either way would be ok?
Old 11-23-2014, 05:05 PM   #4
Highsider
Highsider's Avatar
I think he said "by the edge (only)"
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 11-23-2014, 05:06 PM   #5
tiddlar
Duh! Thanks guys
Old 11-23-2014, 05:51 PM   #6
nvrdone
Widen at the edge due to the curve of the fender. I widened mine 3" and maintained the curve of the fender
nvrdone is offline   Reply With Quote
Old 11-23-2014, 10:06 PM   #7
mr48chev
mr48chev's Avatar
Most of the widened fender in progress shots I have seen show the cut to be about 1 to 1-1/2 inch (s) from the lip that bolts to the bed. That gives the metal worker room to work beside the flange but doesn't put the cut out where you have to reshape the filler a lot to have it work.
Back in the 70's before narrowing rear axles was common widening the rear fenders was real common with rear axle swaps. Not always for the better appearance wise though.
My ongoing truck projects:
Old 11-23-2014, 11:18 PM   #8
_Ogre
_Ogre's Avatar
widening the fender 5 inches will make it an odd duck
easier and imo better looking is to add tubs inside the bed
shop air compressor timer
Old 11-24-2014, 08:12 AM   #9
BigBlocksRule
^ this
and if you can find it, the crew at Kindigit used old fenders to build tubs on one episode of their show, looked really nice when they were done.
BigBlocksRule is offline   Reply With Quote
Old 11-24-2014, 01:31 PM   #10
youngrodder
youngrodder's Avatar
Originally Posted by BigBlocksRule View Post
^ this
Yes, but the Kindigit crew chose suburban/panel rear fenders for their tubs. Those are harder to find and more expensive than rear truck fenders.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-27-2014, 05:30 PM   #11
tiddlar
i actually love the look, i want them widened just because it looks great in my opinion.
Old 11-27-2014, 05:35 PM   #12
tiddlar
PHP Code:
^ this
this truck has the fenders widened 5 inches
Old 11-27-2014, 05:45 PM   #13
tiddlar
It's hard to upload pics. Here is the backside
Old 11-27-2014, 05:48 PM   #14
tiddlar
Another pic
Old 11-27-2014, 06:17 PM   #15
tiddlar
so what do you guys think on this truck i posted??????? im starting to have second thoughts, i widen them.. order the rear end length. .. etc.. would be hard and a lot of money to go back to stock
Old 11-27-2014, 11:17 PM   #16
_Ogre
_Ogre's Avatar
odd duck
widening the fenders looks wrong, imo
look at some of the prostreet builds here, there are many nice ones
stock fenders and 15 to 18 inch wide tires
Old 11-28-2014, 12:47 AM   #17
oldman3
oldman3's Avatar
You asked so here it goes. I don't like the look, I would keep stock fenders, narrow the rear and have tubs inside the bed. Just my 2 cents...Jim
oldman3 is offline   Reply With Quote
Old 11-28-2014, 09:56 AM   #18
crossfire84
crossfire84's Avatar
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 11-28-2014, 10:17 AM   #19
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Another pic
I kind of like it!
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 11-28-2014, 02:30 PM   #20
tony58
I think it could look good but 5" is probably too much. 2" would probably be plenty and a little more subtle.
tony58 is offline   Reply With Quote
Old 11-28-2014, 02:53 PM   #21
tiddlar
your opinions are very welcomed thanks, i need to talk to my metal guy, maybe he can do a mock up so i can have a better look, but we'll see.
Old 11-28-2014, 07:31 PM   #22
tmoble
I thuink somebody used to market fibreglas fenders that were already widened 2".
and what a couple said, easier to ask about this stuff before ordering parts that might inconvenient or expensive to alter later.
and FWIW, I agree with the others, order your rear axle so the overall length including whatever mega-tires you're going to run fit under the stock fenders, put the tubs inside the bed.
tmoble is offline   Reply With Quote
Old 11-29-2014, 09:12 AM   #23
1-ton of fun
polishing a turd
Get a g50 transmission and mount the engine in the bed. That should piss people off! Lol.
Old 11-29-2014, 05:08 PM   #24
tiddlar
Old 11-29-2014, 10:01 PM   #25
BigBlocksRule
You can widen them 2" and stretch 'em out a bit to get almost another inch without screwing up the look of the entire fender. Add the strip on the flattest section front to back, use filler sparingly to round it just a bit. Add tubs. I want to use bottoms of real washtubs in my '55, nicely patina'd.
