Old 11-27-2014, 11:21 AM   #2126
gdavis
gdavis's Avatar
Re: 1968
Happy Bird day guys. I hope you all have a great turkey day. Be thankful for what you have. There are a lot of people that has nothing. So when you set at the table give thanks. George
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 11-28-2014, 02:10 AM   #2127
swamp rat
swamp rat's Avatar
Re: 1968
Absolutely! Happy Thanksgiving back to you too!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-28-2014, 02:27 PM   #2128
silverbear
silverbear's Avatar
Re: 1968
Wow, Patches is coming along very nice. So sorry the used wiring harness did not work out for you. Don't let the amount of time it takes finish her up get you down. You have put way more attention to details than GM even thought about. She will be great one day soon and you will find the experience rewarding.
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
Old 11-29-2014, 02:03 AM   #2129
gdavis
gdavis's Avatar
Re: 1968
I used a lot of the spare parts off the harness that I got from you. But in the end it all will work out. Thanks for stopping by. George
Check out Patches
Old 11-29-2014, 02:17 AM   #2130
gdavis
gdavis's Avatar
Re: 1968
Today I finished wiring the fuseable red wire from the alt to the battery. I didn't like the way it looked. also put the wire in a wire looms and now they are nice and tidy. Tomorrow I will tackle the started and other items for the engine.
oil pressure switch
temp switch
distributor
Check out Patches
Old 11-30-2014, 01:06 AM   #2131
gdavis
gdavis's Avatar
Re: 1968
Today I finished wiring the starter and a little clean up on the wire looms. I will post pictures Monday on the progress. Thursday night the temp. was 34 and Friday the temp was 31 so it was a little cold for us in florida
Check out Patches
Old 12-02-2014, 02:29 AM   #2132
gdavis
gdavis's Avatar
Re: 1968
Today I started testing out the wiring. Got as far as the head lights and they work great. Tomorrow I will have to pull the wiper motor, something is wrong with it. It just makes a funny noise. I had it rebuilt a few months back, so I guess they did not do a good job. I should have checked it out sooner.
Check out Patches
Old 12-03-2014, 07:21 PM   #2133
gdavis
gdavis's Avatar
Re: 1968
got some more wiring done on the old girl.
front and rear clearance lights done
back up lights done
dome lights done
glove box light done
cig. lighter done
key switch done
head light switch done
wiper motor/washer switch done
alt wiring done
starter wiring done
fuse link from alt. done
head lights front and rear. done
front turn signals done
rear turn signals done
hazards front and rear done
no brake lights
I am having a time getting the Ts switch to work. I know it is the wiring somewhere.
Check out Patches
Old 12-04-2014, 01:53 AM   #2134
gdavis
gdavis's Avatar
Re: 1968
back up lights done
dome lights done
cig. lighter done
key switch done
alt wiring done
starter wiring done
But no turn R or L front or rear
no hazard at all
no brake lights
I think my problem with the wiper motor is low amp. I am testing it with 2 amp battery charger. I am going to wait until I have finished the testing before I re-test with a fully charged battery.
Check out Patches
Old 12-05-2014, 06:06 PM   #2135
gdavis
gdavis's Avatar
Re: 1968
does anyone know how to get brake lights? all grounds are good.
all lights are new and have been tested.
Power to the brake switch
power out of the brake switch
power to the column connector
power out of the column connector. but no brakes lights.
Check out Patches
Old 12-06-2014, 08:46 AM   #2136
colgad
colgad's Avatar
Re: 1968
George, sorry I missed your call yesterday. If you have 12v when you step on the brakes out of the switch and thru the column then I would either pull the wire back from the rear of the truck and see if there is a break in the wire or maybe if it is spliced the splice came loose some how. If you are using the factory connector that joins the cab wiring at the plug in the frame I would question the rear harness. Or maybe that plug is loose. Did you use new pig tails from the rear lights? Could be that splice there too. If you don't get it fixed I may be able to come up next week.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 12-07-2014, 01:44 AM   #2137
gdavis
gdavis's Avatar
Re: 1968
I hooked a hot lead to the turn signals and they work so it can't be the harness on the rear. That all is new and the lights are new. I can't get power coming out of the column to the rear. I check the power going in and there is no power coming out of the column, I want to say maybe the turn signal switch is bad. But I don't want to comment to that just yet. If I can't figure it out maybe a trip might not be a bad idea. I have asked of you before and you came up without question. Let me keep trying and see if I can do it and if not I thank you ahead. can you answer me this how many hot wires are there going to the column connector and color. Maybe you know without looking at your truck. Maybe that will at least be a help.
Check out Patches
Old 12-07-2014, 09:14 AM   #2138
colgad
colgad's Avatar
Re: 1968
The turn signal and the brake lights are the same filament. So the turn signal wire Left is the Left brake light wire also. The Right turn signal is the Right brake light also.
ON MINE:
From the brake switch TO the P terminal on the column connector.
From the N terminal on the column connector goes to the Left turn signal bulb.
From the M terminal on the column connector goes to the Right turn signal bulb.
I believe this is the way it works:
So Normally the turn signal filaments are connected via the turn signal switch to the brake switch with the turn lever in the middle position. So if you pressed on the brake the Brake Light/Turn Filament would light for both left and right.
Power to the Turn signal comes from the Flasher if the turn signal lever is moved up or down (R/L). Same filament as brake light. So say if the lever in the Right turn position the Right turn signal is getting Blinking power from the Blinker relay, if you step on the brake the Left filament gets power from the brake switch and it goes solid ON.
I hope this is clearer than mud.
Dave
Old 12-07-2014, 11:14 AM   #2139
Possmguts
Possmguts's Avatar
Re: 1968
Man, I dont feel so bad about my small garage now... I guess one can do great things with what they have right? But at least you have Florida weather on your side... Freezing my ass off in Ohio!
Nice low budget build, coming along real nice.. thumbs up! Love the bench seat... sorta makes me wanna keep mine....
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 12-08-2014, 07:11 PM   #2140
gdavis
gdavis's Avatar
Re: 1968
Well. Today I found out why I have no brakes lights. There was a wire in the turn signal switch that came loose, poor soldering from the factory. I tried to re solder it but it did not work. So I ordered another switch today. It will be here in a few days. So tomorrow I will button everything up again and be ready when it comes. At least I know now that the wiring was right.
Check out Patches
Old 12-09-2014, 04:40 AM   #2141
swamp rat
swamp rat's Avatar
Re: 1968
Glad ya figured it out!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-11-2014, 04:32 AM   #2142
gdavis
gdavis's Avatar
Re: 1968
I was almost ready to call for help.
Check out Patches
Old 12-12-2014, 09:39 PM   #2143
gdavis
gdavis's Avatar
Re: 1968
Got the new switch in from fedex today. I hope to install it soon. Christmas is coming so may not have time for a while. Here is the mess I got with the wiring as we speak.
Check out Patches
Old 12-12-2014, 10:17 PM   #2144
Mustard72
Mustard72's Avatar
Re: 1968
Wiring (and everything else since I last checked in) is coming along really nicely, George. I might have to steal your additional terminal idea in 15 years when I get to that part of the rebuild with Mustard.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 12-15-2014, 01:26 AM   #2145
gdavis
gdavis's Avatar
Re: 1968
Go ahead and steal it, I stool it myself. I am glad to see you still around. Be good my friend.
Check out Patches
Old 12-16-2014, 02:46 AM   #2146
gdavis
gdavis's Avatar
Re: 1968
Any suggestions mates: I installed the turn signal switch and everything looks sweet. I only have one problem. The hazard button will go in and work but it want come back out to shut them off. It is easy to push in, so what is the problem.
Check out Patches
Old 12-16-2014, 06:42 PM   #2147
Possmguts
Possmguts's Avatar
Re: 1968
My new switch is stiff like that too.. You saying you cant get it back out or its just hard?
Old 12-17-2014, 02:57 AM   #2148
gdavis
gdavis's Avatar
Re: 1968
I can take my little finger and push on the inside of the switch and it trips it off. But I can't pull the switch back out. But that is the least of my problems. I installed a 73 to 87 switch, that has a screw in type hazard push pull. When I screw the button in the switch goes crazy. Like I put my left or right turn signal on and all the lights turn into 4 ways. and the minute I take the hazard screw out everything works great. So I am going to mount a push in type button on the dash for the hazards. Case solved. I am tired of replacing the turn signal switch. This id the third switch for this column.
Check out Patches
Old 12-18-2014, 03:50 AM   #2149
gdavis
gdavis's Avatar
Re: 1968
Got all the wiring done. installed the glove box, carpet, steering wheel today. I hope to put the seat back in tomorrow.
Check out Patches
Old 12-18-2014, 05:02 AM   #2150
swamp rat
swamp rat's Avatar
Re: 1968
Awesome!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
