Old 11-28-2014, 03:28 AM   #1
w00dst0ck
w00dst0ck's Avatar
Quick air hook up for rolling around shop?
While I'm waiting on all my parts I want to be able to air the truck up and roll it around the shop.
Anyone have a quick write up on what is all needed? I currently just have the bags and PTC fittings with lines running out.
Thanks!
w00dst0ck is offline   Reply With Quote
Old 11-28-2014, 06:39 AM   #2
IIGW
Re: Quick air hook up for rolling around shop?
i TEE the fronts together, then use a schrader valve.. air it up like your airing up tires.
same as rear.
simple.
or tee them all together and then put a shop airtool fitting on the line, and plug it into the shop air
IIGW is offline   Reply With Quote
Old 11-28-2014, 11:31 AM   #3
68is4me
68is4me's Avatar
i used 3 tee connectors, ball valve, an adapter to the ball valve, and put an air nipple on the ball valve.
This way i can let the air out and just hook up to an air hose and fill it up when needed.
68is4me is offline   Reply With Quote
Old 11-28-2014, 11:43 AM   #4
w00dst0ck
w00dst0ck's Avatar
Thanks guys. That's what I was thinking, and actually ordered everything except the valve already.
