Old 11-29-2014, 12:23 PM   #1
SCOTI
SCOTI's Avatar
Re: replacing rubber fuel line on f-pump leak
Originally Posted by donut View Post
I wouldn't use sealer, light flair, you could double up clamps. If using worm or spring clamps, make sure the screws are offset 90-180*. (don't over tighten the clamps.)
Also make sure the steel line isn't split and your not trying to seal a 3/8" rubber line on a 5/16" steel nipple.
Other thing, you could re-do the steel line or if that isn't an option, you can get a brass, barbed nipple and use that off the pump.
This is what I was wondering. Easy thing to overlook/assume....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
