Hotchkis Front Shocks
I was looking into the Hotchkis front shock setup p/n 70390. It is listed as fitting 63-72.Is there a reason they aren't listed to fit the 73-87? I was wondering if fitment on stock 73-87 a-arms would be an issue? I have moved my lower forward. Does anyone forsee problems with either mounting or length?
Re: Hotchkis Front Shocks
I'll ask our head R&D. I'm pretty confident everything would physically fit, but I don't think we've done testing/fitment on that platform.
![]() Join Date: Jan 2011
Dan he may have the same setup as I have. A 63 to 72 with 73 to 87 control arms. I also have moved my lowers ahead. I moved mine 3/4" forward. It does bind the shock some at the bottom. I am working on a top mount that re-aligns the shock with the forward lower.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#4 | |
#5 | |
It shifts the shock rearward about 1" & put's it just about where it was before the caster mod. I tried it on my CC.
I was figuring I'd move the relocation bracket forward until the angle looked good. Mainly I was concerned about length. The Hotchkis setup uses a short coil and not a dropped spindle I believe.
The upper a-arm bushing seems like it was in the way if I remember correctly...
