Old 01-20-2004, 07:18 PM   #1
Yukon Jack
Yukon Jack's Avatar
Hydraulic clutch and Hydroboost install
Been getting work done on the truck slowly. Got the hydraulic clutch installation basically done last night. Buddy cut me the reinforcement for my firewall with his plasma cutter. Nice piece of equipment.
Another buddy made me the metal shim you see that positions the hydraulic cylinder correctly so the push rod will attach to the clutch pedal.
Got the cylinder mounted on the firewall, threaded the push rod and am using a 5/16" Heim joint to attach the rod to the clutch pedal. Cycles freely and the rod will push in as far as needed. Might have to make a stop to limit the clutch pedal.
Here are some pics.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-20-2004, 07:31 PM   #2
Yukon Jack
Yukon Jack's Avatar
Next pic
Old 01-20-2004, 07:35 PM   #3
krue
Designated A-hole!
krue's Avatar
Looks good. Ya'll do good work.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 01-20-2004, 07:36 PM   #4
Bram
Broke
Bram's Avatar
Hydraulic clutch, thats the way to go! Good work.
72CheyenneSuper1ton4x4BigBlock
Bram is offline   Reply With Quote
Old 01-20-2004, 10:20 PM   #5
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
This may be a dumb question. So what's the advantage to using a Hydraulic Clutch setup?
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 01-20-2004, 11:50 PM   #6
gonebad2
Merciless Butcher
gonebad2's Avatar
Very nice looking. It's a major pita setting it up. I did it one time in a '71. Your setup looks way better than mine did. If I was going to do it again, McCloud makes a hydraulic throwout bearing setup that I would use. Good Job!!!
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 01-21-2004, 11:30 AM   #7
Yukon Jack
Yukon Jack's Avatar
The advantage for me using this clutch is having swapped in a big block in my 4x4 and using headers, I would have had to make custom linkage to get a manual clutch working. Still had to do some modifications to make this work but I think this was the easier way. Plus I had all the parts available off the donor vehicle.
Old 01-21-2004, 02:46 PM   #8
67chevemall
67chevemall's Avatar
It must soften up the cluch pedal too! NO?
I don't know about yours, but a long trip 1000miles and my knee is done for 2 weeks!
adjusting rods also sucks!!
How much is that set up!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 01-21-2004, 08:08 PM   #9
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Looks good.Nice to have friends...eh!:p
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 01-21-2004, 08:10 PM   #10
Canadian694x4
Born To Lose Club
Cool...Thanks for the info Yukon!
Old 01-23-2004, 11:48 AM   #11
Yukon Jack
Yukon Jack's Avatar
Made a change last night to using a clevis rod end rather than the Heim joint. Mainly did it cause I got that setup for the brake pedal booster, but I think with two attachment points on each side of the pedal this will be stronger.
Old 01-23-2004, 11:51 AM   #12
Yukon Jack
Yukon Jack's Avatar
Next I got the hydroboost brake cylinder hung on the firewall. I had to knock the two lower stud bolts off the pedal assembly and drill a couple holes but no biggie. Probably have to modify how the steering column attaches to the firewall as the brake booster bracket covers one of the attachment holes.
Old 01-23-2004, 11:53 AM   #13
Yukon Jack
Yukon Jack's Avatar
Mounted the rod to the brake pedal same as with the clutch. The brake booster rod is 3/8" while the hydraulic clutch rod is 5/16". I cut off the end of the brake booster push rod, threaded it and got it connected to the brake pedal using another clevis rod end.
Old 01-23-2004, 02:01 PM   #14
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Hey Yukon, what are you using for a slave cylinder???
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 01-23-2004, 02:05 PM   #15
Yukon Jack
Yukon Jack's Avatar
The whole setup (brake booster and hydraulic clutch) came from a donor 1989 1 Ton crew cab.
Old 01-23-2004, 02:09 PM   #16
Bram
Broke
Bram's Avatar
Hey Yukon, this is off the subject but, what kind of headers are you running on that 454?
Old 01-23-2004, 02:33 PM   #17
Yukon Jack
Yukon Jack's Avatar
For exhaust I bought Dynomax Cerama-Coated headers. As 67-72 4x4's didn't come with big blocks, I ordered the big block headers for 67-87 BBC 2wd, part no. 86003. Had to massage the engine tower and frame a little, but the headers fit very well now and the collectors should be fine with the transfer case.
Old 01-23-2004, 02:39 PM   #18
1972C10
1972C10's Avatar
Thats Pretty Slick Install there.
I have a 68 Im about to have to fab up a hydralic clutch setup I was considering useing a master cylinder off of an 86-87 One Ton Mainly cause its cheap and it mounts flat
Was the rod proper lenght or close to it for your app?
I might look into the newer model If the 87 Gives Me any Problems.
1972C10 is offline   Reply With Quote
Old 01-23-2004, 04:12 PM   #19
Yukon Jack
Yukon Jack's Avatar
I had to cut some of the length off the rod, thread it and put the end on that you see. Just make sure you take time and make sure the push rod will function correctly. I had to lower the hydraulic cylinder to get it in the right position.
Old 01-24-2004, 01:26 AM   #20
1972C10
1972C10's Avatar
I was going to take the straitedge off my sqaure and put it on the side of the pedel and mark me a hole that would be pretty even with the area where the rod will hook Thats basically all i lack to have my T5 conversion complete.
Old 01-24-2004, 11:35 AM   #21
Mike C
Mike C's Avatar
Looks great Mark! Some first class fab work. Can't wait to see some finished pics.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
