Old 11-30-2014, 10:21 AM   #1
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1968 C10 5.3 swap, the easy way.
Originally Posted by zteca View Post
I am actually having problems with DD mounts, I measured the engine angle to be 7 degrees pointing downward.if I lift the transmission to get 3 degrees, pointing downward, it will hit the cab. By the way I am using the same clamshell rubber mounts vannatta but using a 1980 front crossmember, could that be why and is 7 degrees too much?
Are you using the factory high hump trans cover?
Keith
Convert to disc brakes.
Old 11-30-2014, 11:20 AM   #2
zteca
Junior Member
It's the low hump but I will also need a new rear cross member. When I lift the transmission to the -3 degrees the drive shaft will hit the rear cross memeber. Is there away to lower the engine instead? Thanks
zteca is offline   Reply With Quote
Old 12-13-2014, 12:55 AM   #3
cagodinez
cagodinez's Avatar
Did u have to notch the frame to run the AC lines?
cagodinez is offline   Reply With Quote
Old 12-24-2014, 10:53 AM   #4
vannatta20
vannatta20's Avatar
I did not need to notch the frame for the ac line . I used factory 5.3 ac lines. I had one line cut and welded to get a better angle.
vannatta20 is offline   Reply With Quote
Old 01-01-2015, 05:19 PM   #5
ls1nova71
ls1nova71's Avatar
Ok, tell me I'm not losing my mind, your sig says you live in Vegas, but I would swear I just saw this truck northbound on 291 in Independence about a half hour ago? I was going the other way and the nearest place to turn around was 1/4 mile away, so I couldn't just turn around....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-08-2015, 09:35 PM   #6
ls1nova71
ls1nova71's Avatar
So 8 months later, I saw the truck again at a local cruise in. Not totally loosing my mind, going down the road this truck looks identical to yours.....
Old 08-16-2015, 01:54 PM   #7
vannatta20
vannatta20's Avatar
HAHAHA omg that looks just like it!! Just different wheels!
Old 05-17-2016, 09:17 AM   #8
tow21
Where did u get this is know this is an old post but I'm looking for one for my 70
tow21 is offline   Reply With Quote
Old 05-17-2016, 10:04 AM   #9
vannatta20
vannatta20's Avatar
I used the factory low hump.
