Old 02-14-2012, 05:20 PM   #1
terrylgreenjr
4L60 Shift Linkage
I'm looking to hook up the tranmission linkage. Ive got a 77 Blazer 2wd with a 4.8 4L60 swap. What are the options that I have? Any pics would be great. Thanks
terrylgreenjr is offline   Reply With Quote
Old 02-15-2012, 11:06 AM   #2
Clyde65
Clyde65's Avatar
Re: 4L60 Shift Linkage
locar cable or shift rod assembly. You could go either way
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-17-2012, 07:14 PM   #3
terrylgreenjr
If I can get the factory linkage to hook up , will I be able to go through all the gears? I checked and it is lined up with the old bar linkage and I removed the factory cable shifting part and the linkage from the t350 fit right on
Old 02-17-2012, 10:58 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Some members have trouble getting down to 1st even with aftermarket linkage. I'm using the Lokar ACA-1800 linkage and have no problems, took a few tries to get the adjustment right though.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-18-2012, 09:34 PM   #5
clinebarger
I cant think of any reason (other than grade braking) to "manually shift" a 4L60E. They shift just fine leaving them in 4th gear.
clinebarger is offline   Reply With Quote
Old 02-19-2012, 09:33 PM   #6
farmtrucks
farmtrucks's Avatar
on my 68 I used an original 3speed linkage, and welded a bracket on the 4l60e gear selector that is 1 in. lower and 1 in. foward, it works great and engages every gear.
farmtrucks is offline   Reply With Quote
Old 02-20-2012, 06:20 PM   #7
faribran
very good info.. i have been wondering about this subject myself.
faribran is offline   Reply With Quote
Old 02-20-2012, 09:10 PM   #8
19seventeeCustom
I'm gonna be running longtubes on my swap, and
by the looks of it, the factory rod-linkage is not going
to function properly because of the header collector.
I'm still trying to find a solution...
19seventeeCustom is offline   Reply With Quote
Old 04-14-2014, 10:54 PM   #9
mattcrp1
mattcrp1's Avatar
Any updates?
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 04-14-2014, 11:17 PM   #10
66LSx
66LSx's Avatar
3 on the tree to 4L60e in my 1966 C10
$11 (3/8" HRS rod, rod end, and heat/bend/tap it myself)
after a few heat/bend/fit cycles....
my own shift linkage arm made at work...(next to rusty OEM one)
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 04-14-2014, 11:35 PM   #11
dman1982
dman1982's Avatar
Interesting, I'm thinking of trying to use the stock cable as well
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 04-15-2014, 08:21 AM   #12
truckdude239
truckdude239's Avatar
I used the stock linkage on mine
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-15-2014, 08:45 AM   #13
terrylgreenjr
When I installed everything I just made sure the transmission shift arm was in the same location as it was on the turbo 350. I also took the shift bracket off the turbo 350 and removed the one off the 4l60. Then put the 350 one on the 4l60. It fit perfect with no mods. They used the same d shaped shaft The. Just bolted the orignal shift rod up Worked perfect. Since this post I also pulled everything out of the blazer it was in and installed it in a 91 suburban. It installed the same
Old 08-18-2014, 12:47 PM   #14
mattcrp1
mattcrp1's Avatar
On my 76 2wd i used a shift arm from the frame to the transmission and the u shaped bracket on the shift shaft of the transmission from an 84 700r4 diesel. I found that the shift arm from the frame to the transmission is a different length between the 76 th350 arm and the 84 700r4. The initial adjustment and has the linkage working ok so far. My column is not set up for an o/d transmission and I cant get manual 1st. The short arm is from the 84 diesel 700r4.
IG mattcrp1
Old 08-18-2014, 12:53 PM   #15
boostedc10
boostedc10's Avatar
Just did the Lokar set up on a buddies swap. Only issue we had was it had a stock auto column in it and we had to grind the engagement tab off the stock column.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 08-18-2014, 12:56 PM   #16
Low Elco
Moved the pin up the frame to match the position of the 700r4 shift rod, adjusted all factory stuff, worked like a champ. Now with the 4l60E, the PRNDL sensor makes the trans package 3/4" thicker, so I took 3/4" out of the center of the crossover bar, bolts right up.
Low Elco is offline   Reply With Quote
Old 08-19-2014, 10:59 AM   #17
Jonboy
Slots go on anything!
same here.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 11-30-2014, 08:10 PM   #18
bmcvicker92
id like to see potos of this setup, i bought this item, and its pivotal limitations are too restricted to even come close to my needs.
bmcvicker92 is offline   Reply With Quote
