Old 04-30-2012, 12:06 PM   #176
Dinos63
chevy only
Dinos63's Avatar
Re: Your 60-66 bagged projects?
Originally Posted by camaro_red View Post
So...I guess this was your truck at one time Dino ?
No i wanted it, it was a buddy of mine jeff s
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 06-19-2013, 09:30 PM   #177
zombie J.
Wishbone suspension out back all custom built in my home garage. Z'ed the front end three inches with belltech lowering springs for now, I'm gonna drive it like it is for the rest of the summer then bag the front in the winter. I still need to figure out how the make the steering work when I put the bags up front. Any suggestions.
zombie J. is offline   Reply With Quote
Old 06-19-2013, 11:52 PM   #178
tinydb84
tinydb84's Avatar
What I got from a fellow board member:
David
Instagram: myfabguy
Old 11-04-2013, 09:17 AM   #179
50bomb
50bomb's Avatar
This truck is SICK! Makes me change my mind about keepin my SixtyFive stock height.
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 01-08-2014, 02:57 PM   #180
zombie J.
Slam it! Everything looks better slammed or at least lowered. It's a lot of work but it's worth it.
Old 01-08-2014, 05:33 PM   #181
Downlow2xfo
Downlow2xfo's Avatar
Even a ratty one ton dually...
May your life be like a roll of toilet paper... Long and useful or short and crappy!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=584520
Downlow2xfo is offline   Reply With Quote
Old 12-03-2014, 11:33 AM   #182
Boomscatty
Here's my 60 project. Fatman hub to hub with shockwaves up front and ridetech cool ride in the back. Its a work in progress but getting there!
Boomscatty is offline   Reply With Quote
Old 12-03-2014, 12:49 PM   #183
joedoh
joedoh's Avatar
65 swb with s10 chassis and drivetrain, custom front control arms, most of an ART air bar kit in back, EDC, old MIC manual valves, 22" B.A.D. billets
Old 12-04-2014, 12:18 AM   #184
w00dst0ck
w00dst0ck's Avatar
My '65.
w00dst0ck is offline   Reply With Quote
Old 12-04-2014, 08:17 AM   #185
lowlife4life
lowlife4life's Avatar
Here is mine factory x member shortened pancaked and lca mounts moved up 2 inches.
lowlife4life is offline   Reply With Quote
Old 12-04-2014, 08:22 AM   #186
lowlife4life
Here is a shot of the back sorta hard to see.
Old 12-04-2014, 08:23 AM   #187
lowlife4life
And here is how it sits now front and rear suspension done wiring for engine done now some fuel system and brake lines
Old 12-04-2014, 09:03 AM   #188
MOTOIMPAIRED
MOTOIMPAIRED's Avatar
This is not a bad idea for changing the rear tires if they ever go flat. I had to lift my bed off with my engine lift just to get my rear rims on. I pray I don't get a flat very soon..
MOTOIMPAIRED is offline   Reply With Quote
Old 12-04-2014, 10:03 AM   #189
MOTOIMPAIRED
Here is mine latest project.. Its almost finished now.....
Old 12-04-2014, 01:59 PM   #190
joedoh
joedoh's Avatar
I had to do it, the two sets of rear tires I have are both over 30" tall and are 285s, there was no way to get enough droop out of the suspension to get them on and off, I had to take the bed off with my daughter.
I will eventually mechanize the tilt, right now it is manual but the air tank is right there, a properly placed air bag and a manual valve and some kind of latch for the front and it will open on its own.
blue truck looks great! definitely the style that you wont have any trouble moving!
Old 12-04-2014, 10:39 PM   #191
MOTOIMPAIRED
Thanks!!
I just hope and pray it gets sold before I get a flat tire.. Lol Maybe I should make all the bed connections weather pack connectors in case the bed has to come off again to change a tire...
Old 08-18-2015, 07:08 PM   #192
joe dirt
joe dirt's Avatar
ill bring this thread back to life,
heres my 61
1961 c10 longbed - gone
1964 c10 swb
joe dirt is offline   Reply With Quote
Old 09-21-2018, 05:54 PM   #193
Sac
Bringing this one back from the dead... Anyone have some they want to update it with?
Green Survivor Father/Son Truck
<SeveredTies>
Sac is offline   Reply With Quote
Old 09-22-2018, 08:28 AM   #194
vin63
It's Better With Nitro
vin63's Avatar
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
