Closed Thread
Old 12-05-2014, 08:17 PM   #1
TheBreeze
1970 c20 misc. small parts
Some parts leftover from a '70 c20
Washer fluid bottle $10
Four-core radiator top brackets $5
Green seat belts $10
Horn $5
Front cab mounts & bolts $15
Rear cab mounts & bolts $15
Green Visors, no rips $20
TheBreeze is offline
Old 12-05-2014, 08:25 PM   #2
TheBreeze
Re: 1970 c20 misc. small parts
Gauge cluster Sold
2bl air cleaner spacer $5
C/20 emblems $10
Rear shock mounts $10
Gas pedal Sold
Emergency brake pedal assembly $20
Brake pedal assembly $25
Old 12-05-2014, 08:35 PM   #3
TheBreeze
Jack w/ mounting hardware $20
Vent arms $5
Wiper arms, no pitting $ Sold
Half a gunrack $5
Ground straps, useable $1
Doorhinge hardware $6
Old 12-05-2014, 08:45 PM   #4
TheBreeze
Over load springs 3/4 T $20
Passenger mirror $5
Breather tube $2
Wiper arm linkage $5
Column mounting bracket $2
Hood Latch bracket w/bolts $5
Front bed brackets $5
Old 12-05-2014, 08:59 PM   #5
bluek5
bluek5's Avatar
How are the overload spring mounting brackets for rust? The pair I have are a little rough.
Thanks, Paul
bluek5 is offline
Old 12-05-2014, 09:05 PM   #6
TheBreeze
Low-hump center firewall padding $ Sold
Dirvers side firewall padding $ Sold
Old 12-05-2014, 09:13 PM   #7
TheBreeze
Bolt/retainer/spring kits
Prices vary $2-$5
Old 12-05-2014, 09:16 PM   #8
TheBreeze
Alternator $15
Headlight buckets $5
Rear emergency brake cable w/ linkage, will be seperated from frame members $25
Turbo 350/400 Auto linkage w/ bracket $30
Old 12-05-2014, 09:22 PM   #9
WhiteWhale
WhiteWhale's Avatar
Ill take the 3/4 ton overload springs depending on the cost of shipping.
How much to 91011
WhiteWhale is offline
Old 12-05-2014, 09:23 PM   #10
TheBreeze
Misc. trim, straight $3 ea
OEM hoseclamps 3/69 1-3/16 $5 ea
Exhaust hanger $3
Relay, working $2
Side marker $1
Old 12-05-2014, 09:27 PM   #11
flashed
I will take the wiper arms depending on shipping to Ga 30114 .
flashed is offline
Old 12-05-2014, 09:41 PM   #12
TheBreeze
Paul - It's surface rust, they will end up with some pitting. I can sandblast them if needed.
Old 12-05-2014, 09:53 PM   #13
bluek5
bluek5's Avatar
If you could get me some better pictures I would appreciate it. My email is 2paulstreet@gmail.com
Thanks, Paul
bluek5 is offline
Old 12-05-2014, 10:03 PM   #14
TheBreeze
Sent
Old 12-05-2014, 10:20 PM   #15
Jake1971
Jake1971's Avatar
Originally Posted by TheBreeze View Post
Low-hump center firewall padding $20
Dirvers side firewall padding $15
I will take both. LMK total shipped to 78602
1971 Bone Stock C10 project "Jake"
1997 Sierra SLT factory short bed "Silver Bullet"
Jake1971 is offline
Old 12-05-2014, 10:25 PM   #16
TheBreeze
Paul - $15
Old 12-05-2014, 10:32 PM   #17
bluek5
bluek5's Avatar
I'll take the overloads. Do you happen to have the plates with rubber bumpers off of the trailing arms? My zip is 84043 let me know a total and how you want to be paid.
Thanks, Paul
bluek5 is offline
Old 12-05-2014, 10:41 PM   #18
Jake1971
Jake1971's Avatar
Paul - $15
Which Paul? BlueK5 or me? If $15 is the shipping cost for the firewall pads then the total would be $50 which is acceptable. PM payment info?
Jake1971 is offline
Old 12-05-2014, 10:41 PM   #19
jjzepplin
jjzepplin's Avatar
In line on the overloads if all falls through.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline
Old 12-05-2014, 10:56 PM   #20
Jake1971
Jake1971's Avatar
As agreed, $35 for firewall pads plus $15 shipping. I added 3% to cover PayPal fees as required by PayPal and http://67-72chevytrucks.com/ forum rules: We do not send payment for goods as gift.
Thanks! Paul.
Jake1971 is offline
Old 12-05-2014, 10:59 PM   #21
TheBreeze
Olive glove box door $25
Bed trim $5
Fender trim $ free
Door hardware cups $ free
Window crank, good cond. $3
Door handle, good cond. $3
Trim retainers (more than shown) $ free
Vent window $15
Fan shroud $30
Old 12-05-2014, 11:57 PM   #22
TheBreeze
Bed trim $1
Window crank $3
Armrest, olive green $10
Armrest, cracked/broken corner $3
Passenger fender, front corner seam has separated $75 shipped
Old 12-06-2014, 03:59 PM   #23
TheBreeze
Door panel $10 each
Top trim, painted $5 both
Old 12-06-2014, 04:16 PM   #24
WhiteWhale
WhiteWhale's Avatar
Any luck on shipping quote on the overloads? Paypal?
Old 12-06-2014, 04:36 PM   #25
TheBreeze
Bluek5 - $35 shipping for the bumps and springs, $25 for the bumps (they still need to be cut off)
Closed Thread
