Old 04-08-2014, 02:56 PM   #276
viking427
Re: 8 lug wheels - what's on YOUR truck?
Originally Posted by K20chevy View Post
I was thinking about running these, as they kind of look like the old mags. http://www.hotrodhanks.com/imagesProducts2/16358.jpg The old dually steel wheels also had oval holes, but 4 insted of 5. Maybe powdercoated white with OEM hub caps would make them look kind of vintage too! What do you guys think? Thanks
^^ Anyone know the manufacturer of these slots ?
I think it's the current American Racing 17" 8 lug Ansen Sprint wheel. If so, thats a very rare image indeed, since ALL images on the web of ARE's current Ansen Sprint wheels only show 5 lug file photos.
http://asp.americanracing.com/wheels...shed&section=A
Apparently these wheels are only available in 17x9 wide for 8 lug now, which means you'd need at least an LT275/70R17 tire to fit that 9" wide rim which = about 32" diameter - maybe a bit too large for a stock ride hieght 67-72 C20 without rubbing. What say the masses ?
viking427 is offline   Reply With Quote
Old 04-08-2014, 05:02 PM   #277
Sicklajoie
The Niner
Sicklajoie's Avatar
My Michelin 265/75/16s are a shade over 31.5" in diameter and they're not even close to rubbing.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 04-08-2014, 07:02 PM   #278
viking427
Thanks Sickla, looks like your tires are almost identical in specs to the minimum required tire for these 17" slots;
http://www.tacomaworld.com/forum/tir...5r16-265-70r17
Old 06-19-2014, 10:26 PM   #279
viking427
Just wanted to add another pic of American Racings current "Ansen Sprint" slotted wheel in 8 lug 17x9 configuration for anyone interested. Its been impossible to find any real pics of this wheel in the wild - all the pics out there are "file" photos of the 5 lug wheel. Not bad, pretty faithful to their original 16.5" 8 lug Ansen Sprint slots of the 70's IMO.
Old 06-19-2014, 11:17 PM   #280
TwoTone72s
My 1972 Longhorn has Alcoa 16 x 7 wheels with the aluminum top hats and chrome lugnut covers. The rubber is Lt235 85r 16 Marshall tires. My 1972 Cheyenne Super has painted 9.50x 16.5 steel rims with 9.50 x 16.5 tires, and hubcaps.
TwoTone72s is offline   Reply With Quote
Old 06-20-2014, 02:22 AM   #281
Cobalt964ruf
Cobalt964ruf's Avatar
I have both sets of these from my other trucks. the blue crew cab is actually a parts donor for my 1971 build tho.
Cobalt964ruf is offline   Reply With Quote
Old 06-20-2014, 09:51 AM   #282
chevy2tom
chevy2tom's Avatar
Centerline polished 8 lug 16"
chevy2tom is offline   Reply With Quote
Old 12-06-2014, 06:21 AM   #283
gripnrip
Gripnrip
Hey Ace, where can I find lug nuts to run that style of wheel? Thanks.
gripnrip is offline   Reply With Quote
Old 12-06-2014, 06:24 AM   #284
gripnrip
Gripnrip
Hey 70, if you don't mind my asking, where did you get the lugnuts for those wheels. I don't think stock ones fit the thread on the older trucks.
Old 12-06-2014, 06:30 AM   #285
gripnrip
Gripnrip
Hey Drew, did you need special lug nut to mount the center caps? If so, where did you find them? Thanks.
Old 12-06-2014, 06:31 AM   #286
gripnrip
Gripnrip
BB, where did you get the lug nuts from?
Old 12-06-2014, 08:12 AM   #287
sboris
sboris's Avatar
Heres what im running. Would like to find some slots like below to change it up once n a while.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 12-06-2014, 02:49 PM   #288
I sold my 6" springs, 16.5 x 8.25 white PC'd steelies, and 37/12.50 SSRs I had for my '72. The plan now is 4" lift with 16 x 8 steelies with 35/10.50s and I still have a set of 9.75 x 16.5 aluminum slots with 35/12.50 BFG A/Ts
Old 12-06-2014, 03:12 PM   #289
FirstOwner69
FirstOwner69's Avatar
Go to eBay motors and search for "dual thread lug nuts" or "external thread lug nuts" followed by the size you need (1/2" or 9/16").
Two examples:
9/16": http://www.ebay.com/itm/32-LUG-NUTS-...f6765c&vxp=mtr
1/2": http://www.ebay.com/itm/32-LUG-NUTS-...aa701d&vxp=mtr
FirstOwner69 is offline   Reply With Quote
Old 12-06-2014, 03:29 PM   #290
Jahloha
Jahloha's Avatar
Two examples:
FO69, thanks again for all your help when I was figuring out what to get and buy for the H2s. Appreciate it.
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 12-06-2014, 07:27 PM   #291
FirstOwner69
Glad I could help. Isn't that what this forum is all about?
Old 12-07-2014, 01:39 AM   #292
gripnrip
Gripnrip
Ace, where did you get the lugnuts for your truck? Thanks.
Old 12-07-2014, 01:41 AM   #293
gripnrip
Gripnrip
70, can you tell me where people get the lugnuts for these wheel? Thanks.
Old 12-07-2014, 01:46 AM   #294
FirstOwner69
Did you look at post 289? Those in the links are for the 2001-2007 Chevy and GMC wheels as well as the Hummer H2s if you plan to use Chevy or GMC caps.
Old 12-07-2014, 02:05 AM   #295
gripnrip
Gripnrip
Awesome, that should do it. Thanks for the help.
Old 12-07-2014, 05:52 AM   #296
If you're asking about the conversion duplex lugs like GM used (14mm) to hold 88-up center caps on* that are 9/16, a tire store should be able to hook you up. Possibly a real parts store,too. I get them from wheel accessory guys at big swap meets
*plastic lug cap screws on over lug to hold center cap
Old 12-07-2014, 09:40 AM   #297
Stranny64
Stranny64's Avatar
There is a guy on eBay that sells the external thread lug nuts for our trucks in packs of 32. I got mine from him and I also found someone with new plastic lug nut covers as well as Dually center caps. Good luck!
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!)
Stranny64 is offline   Reply With Quote
Old 12-07-2014, 07:31 PM   #298
Mayo
Cool Truck
Mayo's Avatar
What size are your wheels?
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 12-07-2014, 07:36 PM   #299
sboris
sboris's Avatar
They are 16 x 10 wheel vintiques. Ordered through summit. Cheaper than W/vintiques direct.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 12-07-2014, 07:50 PM   #300
eagleuh1
eagleuh1's Avatar
I got my conversion lugnuts from lugnutking on ebay, make sure you order the right thread size for your studs. Jim
eagleuh1 is offline   Reply With Quote
