Old 12-02-2014, 10:30 AM   #1
troutin55
troutin55's Avatar
New Guy/Truck - Help Needed
I've been looking for an older vehicle for some time now, and have recently purchased a 66 SWB C10, and I'm extremely excited.
I bought the truck off of ebay, and it appears to be in pretty good shape. Has a 5 speed, and a 454.
The rear appears to be lowered a bit, and I'd like to lower the front now. My question is, should I use drop spindles, or use lowering coils? It seems coils are cheaper and appear to help the ride? I plan on doing this work myself, but it's been a long time since I've wrenched on any cars.
I had a set of spindles ordered, but decided to change the order for 3" lowering coils from Summit. They should be here tomorrow. Before I attempt to put these things on, just wanted to make sure I'm on the right track.
Will the lowering coils mess the camber up at all?
Will my tires rub? How difficult is this job? Thanks for the help, I'm sure this topic has been discussed a dozen times, so thanks for helping.
Clint
troutin55 is offline   Reply With Quote
Old 12-02-2014, 10:51 AM   #2
PGSigns
PGSigns's Avatar
Re: New Guy/Truck - Help Needed
You will need shorter shocks or shock relocators. You will need to get it aligned after the springs installed. A tire issue will depend on the rims and the tire size. Good looking truck.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-02-2014, 11:05 AM   #3
morethanstock66
morethanstock66's Avatar
Welcome to the forum. Nice truck, looks like you have a nice leg up in comparison to others here. As for drop spindles and springs. Drop springs allow you to use stock spindles. Typically aftermarket drop springs sacrifice ride quality (are stiffer) to limit suspension travel. Drop spindles allow use of stock springs and keep same ride quality. To go really low you would want to utilize both. To eco PGSigns, you will want to get lowered shocks or shock relocators.
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 12-02-2014, 11:59 AM   #4
Mjminino
Welcome to the forum! Lots of good information using the search function. YEARS and YEARS of past installs and great documentation! Best of luck to you and again, welcome to the forum!
Mjminino is offline   Reply With Quote
Old 12-02-2014, 01:02 PM   #5
Clyde65
Clyde65's Avatar
If you have 5 lug, just go with the spindles and a 2" drop spring, shock relocators and I dont think you would need new shocks. an alignment is always good in this situation too!
BTW, nice truck! you picked a good one!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-02-2014, 01:09 PM   #6
troutin55
troutin55's Avatar
it's a 6 lug, and I think I've decided to use the coil springs that'll be delivered today. I'm not completely sure what's in store for me. I plan using a floor jack to remove the coils, wish me luck!
I am worried that my front tires will rub after all of this is done. I'd hate to go through all of this trouble, only to find out my tires rub.
Thanks for all of your help.
Old 12-02-2014, 01:38 PM   #7
PGSigns
PGSigns's Avatar
What size front tire is on it? If that is an 8" wide wheel with about 4" of back spacing you may need to switch to a 225 or 235 wide tire. I had to when I dropped mine.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-02-2014, 03:55 PM   #8
Clyde65
Clyde65's Avatar
I also did change tires and wheel up front.
I have rally's (5 lug tho)as you do. I used 7" on the front with 2.5" drop spindles and 2" drop springs.
Clyde65
Rebuild of Clyde
support our troops!
Old 12-02-2014, 07:06 PM   #9
Mathew21
Mathew21's Avatar
Welcome to the forum. Great looking truck!
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 12-02-2014, 07:27 PM   #10
Kenfuzed
Kenfuzed's Avatar
You may be limited to how low you can drop the front end. I can already see your headers showing underneath so too low and you'll be dragging.
BTW beautiful truck and with a 454 I'm sure it has some great power.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 12-03-2014, 01:34 AM   #11
Captainfab
60-66 Nut
Welcome to the forum Clint
That is a nice truck
Does it already have discs up front? I would go with dropped spindles over springs. Unless you want to go more than 2.5", then I would go with a 1" spring in addition to the spindles.
You're going to have to be careful how low you go with those long tube headers.
Old 12-03-2014, 06:47 PM   #12
duallyjams
duallyjams's Avatar
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-04-2014, 12:26 PM   #13
troutin55
troutin55's Avatar
thanks for everyones help. I installed a 3" drop coil springs last night, but only got about 1.25" in drop, I read in a previous post how this has happened to other people. May be getting 1" or 2" drop spindles now. I do have disks on the front, with 225 tires. I think I can go another 2 inches safely, we'll see.
Another issue I'm having is with the clutch. When I take off in first gear, the clutch won't let go (i guess that's how you describe it) until that very top of the pedal, or 1 inch from the top. Makes it extremely difficult to drive. Is there an adjustment that can be made, or is this a bigger issue I'll need to address?
Thanks again everybody, greatly appreciate your expertise.
Old 12-04-2014, 01:20 PM   #14
flashed
Welcome from Canton ,several members here live in your area .
flashed is offline   Reply With Quote
Old 12-04-2014, 08:25 PM   #15
Clyde65
Clyde65's Avatar
Drop spindles are only available in 2.5" and 3" drops.
with a 5.5" drop you will need to grind off a touch on your new spindles before you put them on, the wheel will drag. You can get away with changing the wheels to some ralleys that are skinnier, 7" or 6.5" wide.
Also, take a measurement of how your headers are from the level ground, you may not have the room.
I cant help you with the clutch other than if it is hydraulic, there isnt any adjustment. Sorry I am no help here.
Clyde65
Rebuild of Clyde
support our troops!
Old 12-04-2014, 09:46 PM   #16
Monte's62
Welcome to the board from nearby Dallas. Nice looking truck. Have fun with the big block and I hope 2.5 drop spindles will work for you. As someone mentioned earlier I would be concerned about your headers scrubbing if you get to low.
Monte's62 is offline   Reply With Quote
Old 12-04-2014, 10:18 PM   #17
joedoh
joedoh's Avatar
drive it around a while, sometimes drop springs settle after some drive time.
and the clutch pedal on these is abnormally high, at least the donor 65 I had was. I remember my knee being dash high changing gears! sorry I am of no help there.
your truck looks dynamite though, usually the "hi I'm new" threads feature barn finds or trucks rolled out of a field after 30 odd years, both kinds I love but its nice to see a good looking cruiser too.
Old 12-05-2014, 01:51 PM   #18
troutin55
troutin55's Avatar
thanks again for the help.
drove the truck around a little yesterday, and joedoh, you're correct, I guess it settled a little, and probably dropped another 3/4"
I don't plan on dropping it anymore as of right now.
Taking it to the shop on Monday to have the brakes and clutch tended to. Brakes are sticking really bad, and clutch needs to be looked at. Want to get this thing running so I can put some miles on it!
A few other things on my list are getting the speedo working, new carb, new shifter, and possibly new original looking cluster. Thanks for the help. Clint
Clint
Old 12-05-2014, 02:00 PM   #19
troutin55
troutin55's Avatar
Couple pics
Old 12-05-2014, 02:42 PM   #20
m455sx
m455sx's Avatar
Nice truck, post pics after you are finished
1970 442 convertible
1970 Cutlass SX
1962 Chevy Stepside
2011 GMC 3500HD Crewcab SLT DRW
m455sx is offline   Reply With Quote
Old 12-05-2014, 04:07 PM   #21
flashed
Very nice .
Old 12-06-2014, 08:42 AM   #22
Mjminino
You said you're looking for an original looking cluster. What cluster do you have in it now?
Old 12-06-2014, 10:53 PM   #23
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Wow, that's a nice Big Block C10.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 12-07-2014, 04:36 AM   #24
Slow Build
Slow Build's Avatar
Actually CPP Modular spindles are a 2" drop. They are advertised to not move the wheels out like most drop spindles. If you want to keep the rally wheels you may need to use these spindles. The picture below is from another thread about spindles ( http://67-72chevytrucks.com/vboard/s...d.php?t=647229 ). As you can see in the picture of CPP Modulars with 15" rally wheels, if you use a 2.5" or 3" drop spindle the wheel would need to move out so the LCA wouldn't interfere with the wheel without considerable grinding. Also since they keep the wheels in farther it will allow a little wider tire. My plan is to use a 275/60/15" on the 8" rally wheels. That's what I have on the front now with drums and cut springs with no rubbing.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
