Old 12-08-2014, 10:05 AM   #1
amikk97
Truck Wont start!
alright, well pretty much as the title says, i have a no start. it starts if gas is put in the intake but dies out when its all used up. i know its a fuel problem, i just replaced the gas tank and it was running fine after that, and then one day i had it running fine and i turned it off and went back to start it again and it wouldent start. any tips?
Grandpa's '87 Sierra R1500.
amikk97 is offline   Reply With Quote
Old 12-08-2014, 10:59 AM   #2
tlawre87
tlawre87's Avatar
Re: Truck Wont start!
Is the fuel pump kicking on? (assuming you have the electric one in the tank still)
Trevor
74 C20...work in progress.
04 Saturn Ion...Daily Driver
tlawre87 is offline   Reply With Quote
Old 12-08-2014, 11:02 AM   #3
hatzie
Moderator
hatzie's Avatar
Ground wire to the sender/fuel pump came off frame?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-08-2014, 11:57 AM   #4
amikk97
not sure. the fuel guage works but when i turn the key to the on position, not starting it, but just turning it on, i dont hear anything and after like 5 seconds i hear a click. but, its been doing that even when i had it running so i dont know.
Old 12-08-2014, 11:58 AM   #5
amikk97
possibly. ill check when i get home. if it is off the frame, will it make it so it wont start?
Old 12-08-2014, 01:30 PM   #6
hatzie
Moderator
hatzie's Avatar
Yes. This is the ground for your fuel pump.
Old 12-08-2014, 04:38 PM   #7
amikk97
well I went out and tightened down the ground cable and still no start. I put some gas down the TBI and she just sputtered. but, the battery is weak now so its charging up now. any other things it could be?
Old 12-08-2014, 05:41 PM   #8
tlawre87
tlawre87's Avatar
Is this a single or dual tank setup?
Check the fuel pump relay/fuse.
Is the fuel filter good?
Is there any pressure on the fuel
On key on have someone listen by the tank to make sure the pump kicks on (its a whining noise)
This sounds crazy but bang on the bottom of the tank if you don't hear a noise.. The pumps will lock up and banging on the tank can get them unlocked and working temporarily. If it does start however you still need to change the pump.
Trevor
Old 12-09-2014, 11:56 AM   #9
amikk97
its a single tank, ill check the filter today and the fuse. i tried the banging on the tank trick and it didnt seem to work, but ill try again. really not looking forwards to taking down the tank again
Old 12-09-2014, 12:28 PM   #10
bnoon
I'll bet the "click" you hear is the fuel pump relay working just fine. If you don't hear the pump running, check the power coming FROM the relay towards the pump... then if that's good you will need to pull the tank and check power at the fuel pump and the pump operation itself.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 12-09-2014, 01:20 PM   #11
rich weyand
rich weyand's Avatar
If you've had the tank(s) down before, did you replace all the old rubber lines between the tank and the engine with new? They get old and brittle, and pieces can break off inside and jam so as to cork the line internally.
Never work on old stuff without replacing rubber vacuum hoses, fuel lines, coolant hoses, and flexible brake lines.
If you did just re-use the old stuff, you might replace that first, before dropping the tank. That may or may not be the problem, but it should be done anyway, and it's easy and cheap.
Oh, and new clamps too.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
