12-06-2014, 03:16 PM | #1 |
TBI fuel sender wiring, sender to ECM harness connector?
I'm working on an LS swap plan and I'm looking for the three wire connector to plug the TBI fuel sender harness to the truck harness. I would like to make it plug and play with my 1979. Does anyone know how to do this/have part numbers? I went junk yarding and EVERY single last K5 and Suburban had their's hacked out already -.-;;
It would me much appreciated, guys! |
12-06-2014, 05:36 PM | #2 |
Re: TBI fuel sender wiring, sender to ECM harness connector?
I might have what you need. I have most of a TBI harness in my garage from a 1990 suburban. Are you looking for the plug for the fuel pump? Do you have a picture of what you are looking for?
12-06-2014, 07:38 PM | #3 | |
I'm trying to get all my ducks in a row. The K5 is currently in a friends yard for storage but shes getting registration and new tires soon and after that she'll be home. I'm looking to work from the rear forward. She'll have a TBI tank and sending unit, the 381 pump and now I just need to figure out how to plug it all in. |
12-06-2014, 11:08 PM | #4 | |
12-07-2014, 03:53 PM | #5 |
It's a GM weatherpack connector. Should be 2 pin.
Get on ebay and buy a kit, comes with the tool for under $80 if you shop around. |
12-07-2014, 11:13 PM | #6 |
Moderator
^^ Weatherpak connectors are extremely common as are the proper crimp and extraction tools. The actual connector shell part #s are in the GM wiring diagrams.
Get parts & tools from Mouser Electronics, Del City, The Electrical Depot, and Waytek Wire among others... Even Amazon.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-08-2014 at 11:01 AM. |
12-07-2014, 11:53 PM | #7 | |
That's what the ones (dual tanks) on my '87 look like. Power and sender, ground is separate and bolts to the frame.
12-08-2014, 07:20 PM | #8 |
Thanks for the replies, guys!
So my question is, what is needed then to power the fuel pump? Do i need a new harness to the fuel sender or is the carb'd tank sending unit wiring the same? Didn't know that the ground was off the frame, good to know! |
12-08-2014, 09:34 PM | #9 |
I used 14 gauge automotive rated wire in the correct color (gray) ran it down the frame rail alongside the fuel level sender wire, and crimped both wires to the weatherpack connecter.
