12-11-2014, 12:11 AM | #1 |
Aftermarket valve cover oil port
I assume it will take forever to add oil with these aftermarket valve covers since there is a metal screen underneath both caps? What is the purpose of the metal underneath the caps? TIA!
1971 C10 127 in wheelbase Model Number-CS10934 Body Type & Seating-Fleetside 8 ft. Original Factory Price-$2,854 Shipping Weight-3,605 lbs Total Production-206,313 |
12-11-2014, 12:17 AM | #2 |
Moderator
Re: Aftermarket valve cover oil port
baffles to prevent oil getting in the PCV.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
12-11-2014, 12:20 AM | #3 |
Looks like the PCV system was removed on mine. I assume this is not a problem with the way it is set up?
Any tips on getting oil in here or just plan on it taking a while?
12-11-2014, 12:27 AM | #4 |
12-11-2014, 12:50 AM | #5 |
That explains a lot of the oil I am seeing. Guess you are saying extra pressure caused by a lack of a pcv is blowing seals and gaskets here and there (or has the potential to do that)?
12-11-2014, 01:06 AM | #6 |
That's what happens!
You could put a pcv on the passenger side where the breather cap is and a screw in type breather where the cap on your driver's side is. The breather cap doesn't need a baffle. You could open it up under it and help with oil addition. I'm assuming the breather is push in and the cap is screw on. |
12-11-2014, 01:14 AM | #7 | |
12-11-2014, 01:30 AM | #8 |
That makes it easier. Leave the breather where it is and punch out the baffle and put a pcv on the drivers side.
12-11-2014, 09:21 AM | #9 |
If I go back to a pcv I would connect the pcv hose end with the hose with a bolt in it coming of the front of the carb in the center of the above picture?
1971 C10 127 in wheelbase Model Number-CS10934 Body Type & Seating-Fleetside 8 ft. Original Factory Price-$2,854 Shipping Weight-3,605 lbs Total Production-206,313 Last edited by domano 68; 12-11-2014 at 09:32 AM. |
12-11-2014, 10:20 AM | #10 |
Yup!! Hook the new hose there.
12-11-2014, 10:21 AM | #11 |
That should work just fine. Know that you may need to readjust your idle mixture and idle speed to account for the 'vacuum leak' of the PCV system.
-- '67 Chevy Stepside 250 Inline 6 Megasquirt Fuel Injection T5 5 speed conversion Ferric Oxide impregnation throughout |
