Re: Power steering with LS motor
FYI, I currently have a 78 C10 power steering box with my 2005 Vortec 5.3 power steering pump. I'm on my second NAPA made up, leaking, dripping power steering hose. I'm going with the following solution SOON. Contact Pat at Benchworks in Scottsdale Arizona. They have done lots of our 67-72 Trucks with Vortec Engines and have The Best set-up all figured out. They have a later 80s Power Steering Gear Box (Best Ratio) that also uses the late model GM Metric 16 MM o ring (2006 Vortec V8 pump) to 12 MM O ring (steering box) pressure line and the new generation rag joint required. They can UPS you all that stuff at way better prices and in my experiences with them, probably better quality than what you've been talking about here
Bottom line if you ever need a replacement power steering pressure hose in the future, walk into any auto-parts store and get an OEM replacement, no jury-rigging multiple hoses and fittings that can leak. Just a thought
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" Last edited by Lees68GMC; 12-11-2014 at 01:20 PM. |
Not exactly sure what the question is. You would do a power steering swap with the gear and linkage just as if it had a 350 (or whatever). You would use the LS power steering pump and reservoir. Run a return line from the gear to the reservoir. If the return hose is not long enough, add on with a nipple or replace the hose part with a longer one from a hydraulic shop. On the pressure hose you can buy custom ones, but the easiest way is to add a JIC fitting in the middle and splice together there. Take the original hose and route towards the pump; then the hose from the pump towards the gear. Cut both in the middle where they intersect. Have a JIC (or sometimes called a "bullnose") fitting installed in both-male in 1 and female in the other. Connect and cover with loom and you are set. JIC fittings are available for all common hose sizes. This also gives you the ability to turn the hose how you like it before connecting in the middle so you don't have to be exact as when you made one.
Just curious-why carb an LS? The cost of carb vs: computer is not that much savings and you still have to run an electric fuel pump.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#3 | |||
![]() Join Date: Oct 2013
And I'm going carb bc I got a good deal on a motor with some of the carb set-up already, didn't want to fool with wiring, and i like the look of it. I feel it keeps a little bit of the old school feel under the hood. I'm planning to cover the coils some sort of valve cover set-up.
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
