Old 12-12-2014, 11:22 AM   #1
Ironhorse
Ironhorse's Avatar
Choke / Throttle Knob - Same ?
I have some how acquired a threaded knob with the standard front not the CST stainless front. Sorry for the pics, not the best I know. Hard to see but the inner portion of the knob is threaded. Knob heighth measures 1'' front of face to the back. Much shorter than the slip on radio knobs but looks quite similar. Is the knob the same as used for the manual throttle and the manual choke? Not sure where I got it from, have parted a couple trucks and made several parts buys from time to time. Can any one tell me if they are inter-changeable?
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 12-12-2014, 11:29 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Choke / Throttle Knob - Same ?
I can't tell from the pictures. Does it have a set screw also? I know that the wiper/washer & the throttle knobs both have set screws, but the choke knob may screw on.
LockDoc
Leon
Old 12-12-2014, 11:32 AM   #3
Ironhorse
Ironhorse's Avatar
Leon, no set screw as the washer knob has. Was not aware the choke know had a set screw? As mentioned, hard to see in my less than professional pics but it does have internal threads.
Wellington, Ks
Old 12-12-2014, 11:42 AM   #4
LockDoc
LockDoc's Avatar
You may have misread my post. I don't know for sure if the choke knob had a set screw but I know the throttle knobs did, so if it doesn't have a set screw it can't be a throttle knob....
LockDoc
Leon
Old 12-12-2014, 11:54 AM   #5
Ironhorse
Ironhorse's Avatar
Well with it having no set screw I would say that the knob is neither the w/s washer knob or a throttle knob. That leaves the choke knob only since it has no shaft like the H/L knob. Thanks for the info Leon.
Wellington, Ks
Old 12-12-2014, 12:13 PM   #6
LockDoc
LockDoc's Avatar
No problem. Just for information in the thread, even though the throttle knobs and W/W knobs both have set screws they are different lengths. The throttle knobs are longer.
LockDoc
Leon
Old 12-12-2014, 12:29 PM   #7
sboris
sboris's Avatar
I know my choke knob is threaded. The knob itself threads onto the shaft. No set screw.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 12-12-2014, 12:35 PM   #8
LockDoc
LockDoc's Avatar
That's what I thought Shawn but I was too lazy to go out to the '67 and confirm it.... .. Thanks.
LockDoc
Leon
Old 12-12-2014, 12:39 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Choke knob and Manual throttle knob. Note the differences.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-12-2014, 12:41 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Uno mas. The threaded shaft on the manual throttle is a larger diameter then the one on the choke.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-12-2014, 02:26 PM   #11
LockDoc
LockDoc's Avatar
Neither of the manual throttle assemblies I have, have threaded knobs, they both use set screws as shown it the picture. I am using a W/W knob for one of them. You can see how much shorter it is. The coarse threads on the shafts are for fine tuning the throttle setting. You can screw the knob in or out to change the setting of the RPM slightly. Zepp, If your throttle knob has a set screw I'm betting it doesn't have threads either.... I don't see a set screw in either picture but it may be hidden.
The second picture is of the choke cable. In the picture you can see two small flats on the shaft. That is so you can hold the cable to unscrew the knob. I use needle nose pliers to hold it.
LockDoc
Leon
Old 12-12-2014, 02:36 PM   #12
leddzepp
Moderator
leddzepp's Avatar
It has a set screw, and from the appearance it looks threaded to me. I've never examined it that close or tried to remove it. It is original so it is probably not threaded as you state.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-13-2014, 08:15 AM   #13
Ironhorse
Ironhorse's Avatar
Thanks for all the replies and the good info. Always something to learn on these trucks and this board is the place to do it for sure. Much appreciated the info and the pics.
Wellington, Ks
