Headlight conversion question from a noob
So I picked up a 72 swb4x4 and I wanted to know if somebody have converted hella off-road lights as headlight?
I know it's probably the best idea but would it work? |
Re: Headlight conversion question from a noob
Do relays first cause you will be disappointed, but those lights and relays will make an awesome combo
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
![]() Join Date: Feb 2010
Yeah the relay upgrade for your 'stock' headlights will be your best bet for safety and avoiding any local law enforcement hassles. But you can always setup your Hella's for use with your high beams. Once you get the relays installed, it's that much easier to add the others in without compromising the original wiring.
Welcome and good luck with it!
-- '67 Chevy Stepside 250 Inline 6 Megasquirt Fuel Injection T5 5 speed conversion Ferric Oxide impregnation throughout |
Is there a thread on some one doin it I would love to do this and how would u use high beam?
I got lmc relays and they were just plug and play, I think I have the installation on my build thread. Pretty straight forward process though
Ok I'll look into the LMC online see what I can find and if I do conversion since it's an off road light that's only 1 1/2 wide I can just remove the stock buckets and just drill a hole for the Hella bracket that comes with the light correct?
And thanks for the reply everybody |
Hella has conversion headlights, is that what you are talking about? ...or are you talking about using Hella driving lights or fog lights as headlights?
I'm talking about just using a set of Hella 500 I have in my garage and use those as a headlight
Hmm, if it's a driving light it'll pretty much be like driving with your high beams on all the time with no low beam. If they're fogs you'll get a nice wide stripe and nothing else. A pretty bad plan that'll be worse than anything you have now, and will probably get you pulled over often.
^^^ I concur.
Ok thanks skorp how do I tell if it's a fog or a spot type? And would it really be that bad of an idea to do I don't drive it often at night since I work Ike 5 min away from work. Would it be that bad of a thing to do
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#14 | |
But in answer to your question fogs generally have vertical grooves in the lens and driving lights curved grooves. Spots are clear no grooves. Oh and on a 4x4, driving lights would be an instant ticket, and fogs would be comically bad. |
#15 |
Alright so I read the link thanks 70cst but like all of us/(some) I'm tryin to make my truck cool but on a budget. And by buget I mean tight buget I work at a local wrecking yard and to be honest I have headlights but I don't have the ring holders that hold them to the bucket with the adjustment screws, so that's when I seen my hella 500s at my dads and figure I can use them since we haven't had a 67-72 come on cuz to my knowledge I need the 1inch wide rings right? But after I read the link they look great but it sounds like a lot of work to retrofit headlights with hid or projectors, not alone the bulbs are expensive if bought quality ones.
So I'll just wait till another 67-72 comes up at work and grab the rings. Unless someone know if there's an way to make 74-87 rings work since there a lot thinner???..... Once again thank you guys for helpin me get my truck that much SAFER and road worthy |
#16 |
Moderator
![]() Join Date: May 2007
If you are on a budget, Txfirefighter has an excellent write up in FAQ on making your own relay harness dirt cheap from junkyard relays. Do this and get a pair of sealed beam Sylvania Silver Stars from your local parts store. The difference will be incredible and you won't waste a bunch of money chasing over-the-top lighting that is unnecessary on a truck that you drive occasionally at night.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
#17 |
Thanks leddzepp I'll look him up, thanks everybody who helped out sending me some great info and opinions and options
#18 |
Are you needing the retainer ring that holds the sealed beam to the bucket with three little screws?
Those are reproduced and run about $8.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#19 |
Old member
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#20 |
Yes SS I just need the retaining ring I had no idea theyare tha cheap can I get them at my local nap or on the LMC web?
Andy4639 that looks clean most of the lights I've been lookin at say I have to modify the headlight buckets because of the desin of the back of the light it self |
