![]() Join Date: Jul 2007
Re: front clip ID help please
Mid 80's 305 jives with a mid 80's G. body.
The rear axle should have a number stamped somewhere on the front side of the passenger side of the axle tube that tells it's application. If the axle was originally a G body axle it should show signs were the brackets were cut off and ground down but it may have come out of a Nova or Camaro leaf spring car. A lot of guys would rather buy a Nova or Camaro axle rather than clean up the brackets off the axle they have.
whats the part number on the spindles? look on the inside. measure the length of the sway bar too as well, from eye to eye where it hooks to control arm.
1959 Chevy Apache (sold) 1958 Fleetside Current My builds: http://67-72chevytrucks.com/vboard/s...d.php?t=606412 http://67-72chevytrucks.com/vboard/s...=1#post7560906 |
![]() Join Date: May 2007
GM metric G-body. but you knew that 12 posts ago. ![]()
A320 Pilot/USAF Retired
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#7 | |
#8 | |
TES521315 |
