Old 12-13-2014, 04:16 PM   #1
Coneboy
Help?
Hey guys, I picked this '80 GMC Jimmy up a couple weeks ago. I'm currently replacing the floors, rockers and tailgate panel. I have a new poly body mount kit but need to replace the body supports. Figured I might as well replace all of em. Does anyone have a diagram showing which I need to order, and their location? Also, I have included a picture of when I bought it - it has 33/12.5-15 tires on it. There are no blocks in the rear but it looks lifted. I have no idea what springs are in it. Does this look like it has already been lifted? Thanks, Brian
http://i1284.photobucket.com/albums/...psa60d6265.jpg
Coneboy is offline   Reply With Quote
Old 12-13-2014, 06:09 PM   #2
russgt
russgt's Avatar
Re: Help?
Flip through LMC truck's catalog, its pretty good.
http://www.lmctruck.com/icatalog/csb/full.aspx?Page=40
I recently did some of the same work that you are doing on my 76' K5, so if I can help let me know.
70 stepside
76 blazer
86 Sierra Classic
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 12-14-2014, 06:25 PM   #3
mattybilt79
Re: Help?
Look at the lmc cat as stated for parts. Doesn't look like its lifted to me just taller tires. Look at front springs if they are flat or over arched then probably stock should be only 2 or 3 leaves in the pack. I've seen some crazy home made lifts though with add a leafs and re arched aka bent stock springs. Usually lift springs have part numbers painted on the top leaf too.
85 3+3 with a tee-pee
mattybilt79 is offline   Reply With Quote
