Old 12-10-2014, 07:58 PM   #1
Jon01
Jon01's Avatar
Stock LS1/4L60E Swap
I also have a complete LS1/4L60E out of a 2001 Trans Am.
If the built one below sells, I'll keep this one or v/v.
Motor is mostly stock - has new lifter trays, GM lifters and LS9 valve springs.
Trans is a fresh rebuild with zero miles.
Comes with PCM, harness, F-body accessories and oil pan.
This one is 2,900+shipping from central Iowa or I can meet in the general area.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 12-13-2014, 01:46 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Stock LS1/4L60E Swap
Not knowing too much about the newer engines I presume this is a 350.
Will this fit in a '67 pickup without too much trouble? Mainly I am wondering about the oil pan and stuff since it came out of a car.
How hard would it be to integrate the LS wiring with the '67's loom? Would I have to buy one of the aftermarket looms?
Thanks,
LockDoc
Leon
Old 12-13-2014, 10:40 AM   #3
Jon01
Jon01's Avatar
Leon,
It's an aluminum 346/5.7.
Yes, f-body pans will fit in easily, you'll need a set of trailblazer ss headers or manifolds.
The engine harness will need modified - there are a lot of unnecessary wires that are removed and fuses are added for various things - o2 sensor heaters, fans, a/c, cpm, etc...you can have that done for anywhere from $2-300, get a set of $40 adapter plates off of ebay then it is a very simple installation.
Old 12-13-2014, 11:20 AM   #4
LockDoc
LockDoc's Avatar
Leon,
OK, thanks for the info. I will do some thinking on it....
LockDoc
Leon
Old 12-14-2014, 01:46 PM   #5
LockDoc
LockDoc's Avatar
I will take this engine/ trans combo Jon.
Thanks,
LockDoc
Leon
Old 12-14-2014, 08:07 PM   #6
Jon01
Jon01's Avatar
Super, nice talking to you today Leon! See you next weekend hopefully.
