12-14-2014, 02:22 AM | #1 |
Door panel screw inserts
Could someone please send me a picture of the nylon inserts in the door of a 67-71 chevy that are used to attach the metal door panels
Thanks |
12-14-2014, 02:39 AM | #2 |
Re: Door panel screw inserts
My 68 has threaded metal inserts, believe welded in.
12-14-2014, 02:53 AM | #3 |
I'll have to take a look tomorrow, I'm pretty sure they're not nylon inserts.
12-14-2014, 08:26 AM | #4 |
they are metal but the square plastic license plate plugs fit and will work till you get the correct parts
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
12-14-2014, 08:35 AM | #5 |
A couple of the metal inserts were missing when I first got my truck, so I got some nylon inserts popped them in and tapped them. Its quick and easy.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
12-14-2014, 11:05 AM | #6 |
Yeah, the square plastic license plate clips will fit fine and do well to work for that.
12-14-2014, 12:32 PM | #7 |
get at ace hardware
12-14-2014, 03:35 PM | #8 |
member #16
Wes at classicheartbeat has the capture nuts.
http://www.classicheartbeat.com/cata...ener%20Set.htm http://www.classicheartbeat.com/nuts_&_bolts1.htm
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
12-14-2014, 04:44 PM | #9 |
Use nutserts. They are permanent.
12-14-2014, 05:10 PM | #10 |
12-14-2014, 05:28 PM | #11 |
12-14-2014, 06:16 PM | #12 |
12-14-2014, 07:31 PM | #13 |
use cage nuts they are 1/4 20
12-14-2014, 09:28 PM | #14 |
Just like a pop rivet. Screw the nutsert onto the mandrel, insert it to the flange and squeeze the handle of the tool. Then just turn the mandrel to remove the tool. The result is a threaded hole in almost any size you choose. Just buy the correct nutsert for the thread size you need..
12-14-2014, 09:43 PM | #15 |
Thanks for all the input.
My truck is a 72 GMC but I don't personally care for the plastic panels. I changed the door operators to the shorter 67 style to accommodate the earlier years metal panels. I ordered new panels from LMC and the mounting screws. The screw heads looked really large (larger than some I've seen in other parts pictures). What didn't make sense was the panels had drilled holes and the screws were meant to be countersunk. I checked an old metal panel and the holes were countersunk. Checking the screws the heads were too large to fit fully into the panel recess. I've gotten a lot of parts from LMC and have had good luck, but it looks like the manufacturer missed the countersinking depression on the panels. |
12-14-2014, 09:46 PM | #16 |
The heads on the screws on the classic heartbeat site are smaller
12-15-2014, 08:33 AM | #17 |
Yeah, the Cage Nuts from Ace Hardware are the same as OEM and they snap in the rectangular hole on the door panel bottom [67-71 for sure].
