Cutting a CPP 3" front coil?
I am running the 3"/4" drop kit from CPP. I would like another 3/4" to 1" drop up front. Anybody cut 1/2 coil off a CPP coil up front? Any issues? Recommendation/thoughts? I have about 3" of suspension left so I don't think it should be an issue. Just checking.
I believe if I was that close, I'd first take a hard look at running a shorter front tire. I've never cut one of their springs, btw.
Sam |
Re: Cutting a CPP 3" front coil?
Tires are brand new so not an option. Plus a shorter tire would make the gap larger. I've cut a set of Eibach springs on my 69 Camaro but not a set of CPP springs. Mainly asking that if someone has cut them before did 1/2 coil net a 1" drop...roughly. I want more of a rake in the front.
I was in the same boat so to speak on my 70. I had 3" springs of unknown brand because I got them from a friend. I cut 1/2 coil off, the next time I jacked the truck up the front springs fell out on the floor. I would advise against it.
355,vortec heads, Doug Herbert cam, Performer intake, 750 Holley, Hooker Comps, 2 1/2 duals w/Aero Chambers, 2500 stall and 3.73 posi. |
Cut half a coil. 1" extra drop, no issues, no change in the ride! It sits perfect now!
You know we're gonna need before and after pics, right?
I have before. Need to take some after shots. I was so happy with the outcome I forgot to snap a few pics. I will update my build thread if my email starts working so I can pull off the photos.
