Old 12-12-2014, 06:19 PM   #1
lynx5653
lynx5653's Avatar
custom suspension 58 apache
Could any of you 4x4 guys take a look at this suspension set-up and tell me if you see any problems or concerns. This truck is being built for road use only.
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
Old 12-12-2014, 06:35 PM   #2
b454rat
Re: custom suspension 58 apache
By far an expert, but looks like both front and rear arms are too short. Won't get much axle movement up and down....
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 12-13-2014, 12:47 AM   #3
72 Copper C-10
72 Copper C-10's Avatar
im no expert either but it looks functional for road use only, the front reminds me of a newer ford e-450
72 Copper C-10 is offline   Reply With Quote
Old 12-13-2014, 04:13 AM   #4
andrewmp6
It should ride ok depending spring rates in those coilovers.If you want it to ride like a caddy longer arms and longer coilovers.
Old 12-14-2014, 01:19 PM   #5
Redcap
Might want to think about some bracing on those rear coilover mounts and I'll agree with the others...arms are way too short.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 12-14-2014, 03:39 PM   #6
lynx5653
lynx5653's Avatar
Thanks for the feed back. Will see what can be done with arms and coil mount.
Daily driver
Old 12-15-2014, 06:04 AM   #7
andrewmp6
On some jeeps the stock front arms are that short.Its a street truck it should be fine that short.How long are the coilovers and how much total travel do you have?
Old 12-15-2014, 08:33 AM   #8
lynx5653
lynx5653's Avatar
I believe they are 17 inch coils and are set for 3-4 inches of travel.
Daily driver
Old 12-15-2014, 01:47 PM   #9
61K10
61K10's Avatar
on road only it should be ok. not much travel with coilovers. Like Redcap says beef up the coil mounts.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
