Old 12-15-2014, 12:23 PM   #1
pound41
Blower Motor only works on Med
Hello:
I bought this 71 blazer with A/C about a year ago. blower motor only worked on medium. I replaced the relay up by the kick panel it all worked great. This year goes back to only working on medium. I have replaced the relay again, blower motor and switch. Still no change. What else can it be.
pound41 is offline   Reply With Quote
Old 12-15-2014, 12:25 PM   #2
MARKDTN
Re: Blower Motor only works on Med
Resistor pack.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-15-2014, 12:29 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Check the ground on the relay. I had the same problem you describe and that was the culprit.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-15-2014, 01:55 PM   #4
pound41
I will check the ground on the relay
if it is the resistor pack where is it located
Old 12-15-2014, 02:13 PM   #5
mrein3
mrein3's Avatar
I bet the switch or the plug behind the switch is fried.
I converted my truck to AC. When doing that, I discovered that EVERY used blower motor switch I found in the junk yard was not working and the plastic plug that plugs in the back of the switch was melted. I ordered a new switch, new plug, and ran all new wires with the correct color and gauge according to the wiring diagram.
That was about 10 years ago.
Fast forward to last winter. My blower didn't work on one or two speeds. Sure enough my brand new plastic plug was fried. Again. And it took the switch out. Again.
I was in a hurry so I ordered a couple of new switches and a couple new plugs, replaced them, and put on my list of things to do "find orange, yellow, light blue, and brown wire in 12 gauge."
Stock wire is 14 gauge. Obviously it isn't beefy enough.
Anybody know where I can find light blue stranded 12 gauge wire? The other three colors are easy to find.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-15-2014, 04:12 PM   #6
MARKDTN
http://67-72chevytrucks.com/vboard/s...d.php?t=532916
'83 K20-TPI
'73 C10
'14 Suburban-DD
