New to me and need some guidance
I just bought this 64 shortbed with a 292 3 speed manual trans with a 3.08 rear gear. The challenge is the trans does not have a synchro 1st gear and when trying to turn corners that are to slow for second gear it is all but impossible to get it in 1st until you are almost stopped.
Is there a 3 speed that will replace the one in my truck with a synchro 1st gear. I really like the 3.08 rear gear for highway driving. Any potential easy and inexpensive options to my problems would be appreciated. Thanks
![]() Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS Last edited by HSRACER; 12-16-2014 at 01:31 AM. |
Re: New to me and need some guidance
Here is a picture
![]() Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
Darn I phone posting!
![]() Join Date: May 2007
double clutch. push clutch in shift from second to NEUTRAL let clutch out. Push clutch back in shift to first. once you start doing it you wont be able to un do it.
Will that really work? Isn't there a synchroed 3 speed?
of course it works! thats how everyone shifted before syncros. I think later 3 speeds were syncro 1st, but that one is not. your problem is the 3.08 rear gear makes it work on the highway but hard to drive at low speeds.
I forgot to mention, you need to blip the throttle a bit to get the revs up before shifting into first. you could always lug it out in second, the 292 has a ton of bottom end torque.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 Last edited by joedoh; 12-16-2014 at 03:47 AM. |
Leave it in Second. Slip the clutch, wind the engine up. If its pulling at1000 to 1200+ rpm, it'll pull all but the steepest incline while turning. Its a long stroke torque motor. Don't be afraid to use it.
Double clutch...
![]() learned that trick long ago... ![]()
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
![]() Join Date: Mar 2013
Here's how I shift to 1st...66 chevy c10 with an sm420 4 speed with granny low....shift down to 2nd...let the truck slow down to idle...Without pushing the clutch in pop it out of 2nd..tap the gas as you pop it out...then slide up to 1st by rev matching....meaning reving the engine to the speed it would take to go that speed in 1st and it'll fall right in. Its really easy to do, especially when ya get the hang of it.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
66 or 67 chevy car and truck and later Saginaw 3 speeds are all synchro
1961 chevy K10 my build is------------61K10 build |
...just another truck junkie..
![]() Join Date: May 2009
Learn to double clutch and you will have learned something that is literally a dying art. Impress your friends with your clutch skills!
Mike "Bear" Shea |
Sweet truck.
