![]() Join Date: Sep 2007
Hello. Does anyone in the Portland OR./Vancouver WA./ Seattle WA. area's, have a Dana 60 from a 3/4 ton 4x4 or '70-'72 Longhorn for sale? I'm wanting to get rid of my Eaton in my '71 Longhorn and convert to a Dana 60. I'm willing to travel out of my area for one. Any help is much appreciated. Thanks Mike.
Always on the hunt...
![]() Join Date: Sep 2006
Re: WTB: 4x4 or LONGHORN DANA 60 rear end
Hi Mike, I see you listed 70-72 above. Remember in 71 they went to the larger 9/16 studs, can be changed but may as well look for the right one as they are out there. Mel
I have one but its a long trip I will put on a pallet and ship though I will send pics if interested. It is fresh with a posi unit and 4.10 gears gears are original but in super shape new bearings and seals etc. Drive train specialties did the work got 900+ in it will sell for lot less to get rid of it it is Hub to Hub I have the original brake drums also
Hey Mel. Thanks for reminding me. I know we just talked about this the other day, I forgot. I'm just hoping someone in the areas I mentioned above might have something. Thanks Mike.
Thanks for the offer, but to ship this would have to be truck fright. Shipping would be to much to come out to Oregon. Only way I could offer anything would have to be about $200 plus shipping for it to be worth my while, and I know you wouldn't go for that amount. I do appreciate the offer. Someone in my area must have one? Thanks Mike.
![]() Join Date: Jun 2005
I have a good housing, 4:10 or3:73 or 3:54 gear and posi unit and probably axles, but I'm far away. I had a 72 Chevy K20 that had the eaton w/posi and wanted to change it to dana 3:54 front and rear.
Let me share, the info I found out searching for a conversion from the eaton to dana. The K20 Dana was installed in all GMC. The housing is different in the spring perch mounting and shock mounts on the K20 dana and the c20 dana, but the guts all interchange. My Chevy Custom Camper has the C20 dana. Hope this helps and maybe some else has some info. |
"Trucks with Class"
![]() Join Date: Jul 2000
[B]I have a complete, never opened, 71-2 Longhorn diff. 3:54 BB ratio. It is still sitting on wheels & tires, so it is not down on the ground. It is outside. $300
Frank, I'm very interested in this diff. Could you send me some pics. of diff. and could you measure distance from brake backing plate, to center of spring perch? Price is no problem, sounds fair to me. If all works out on my end, I could drive up this week, Tuesday or Wednesday. Sounds like just what I'm looking for. I'll be in contact later this week. Thanks Mike.
![]() Join Date: Jan 2013
I have a complete 70 GMC rolling frame 2 wheel drive with the engine, turbo 400, dana 60 rear I am looking to get $500 for the whole thing. maybe someone can tell me if a 2 wheel drive rear is the same as a 4 wheel drive. this one drove out good when I parked its been in the weather since 08/15
Hello. Is this a Longhorn or a regular long bed pickup? Wheel base of a Longhorn is 133 inches, spring location on the perches is 1 inch difference, that's the reason I need one out of a Longhorn. Your price sounds good, just need's to be a Longhorn frame. Thanks for the response, Mike.
Search is over! Frank had just what I was looking for. Now it's home waiting for the swap. Thanks Frank.
