Headlight connectors
I assume that folks have replaced their corroded old plugs going to some of their lights. I'm wondering if you've been able to find the small female ends that go inside the plastic plug for the headlight connection? They look similar to a regular 1/4" female spade plug, but obviously a little different so they lock properly into the plastic plug.
Been looking for a box of them so I can start making replacements, but haven't been able to find them.
'84 K20 350/465/208 |
![]() Join Date: Aug 2014
Re: Headlight connectors
have you tried LMC Truck, here is a link to the headlight component page for your '84
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=192 |
Thanks - I've been staying away from LMC recently, so I didn't even check to see what they had. I was hoping to just be able to find the internal connectors for each wire and not have to order anything - just not sure where to find them locally or what the proper name is to ask.
Should be something like this I think - ![]()
Moderator
![]() Join Date: Oct 2008
The old sealed beams use an H4 pattern plug. They may be Packard 56 terminals like your picture or they might be larger like you'd find in an F7 ISO relay socket. I've never looked.
These guys sell H4 headlamp plugs and terminals. http://www.cycleterminal.com/headlight-connectors.html
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
http://www.napaonline.com/Catalog/Ca...165_0282408814
Napa has a good selection of OEM terminals. Ask their salesperson for the book on rack and thumb through it. Above terminal looks like the one you pictured.
04 Yukon XL 2500 w/ Quadrasteer ![]() 61 Chevy C60, 261 inline six 86 Chevy C20 2wd, Banks 6.2 05 GMC Sierra 2500hd Duramax |
#6 | |
Packard 59 terminals were commonly used in many GM sealed beam headlight connectors. They're basically a larger version of the Packard 56 terminals and are available at NAPA as part # NW725448.
I couldn't find the terminals, but I checked napa today and they did have the connectors, but they didn't seem great - the quality wasn't there. It made me think that my local truck store might have the connectors, so I checked there too. I found some H4/9003 connectors that looked great. Heavy enough wire, sealed plugs and some nice wire loom on there too. It was a good find.
I use Delphi 59-series terminals...I stock 14-16ga and 10-12ga female versions for my headlight harnesses. Napa carries a cheap version of them which aren't as stout as OEM Delphi. I'd still keep an eye on your headlight connectors you chose however-Dorman is Chinese made and the wiring is more brittle as is the insulation which is not j1128 spec'd which means its not rated for under hood use. Why they sell that stuff I have no idea.
With relay power you'll be able to get more voltage out of those lights and the first area to watch is the wiring-in particular the grounds-GM used heavy gauge 1/4" 14ga grounding rings on the radiator support so if you replaced them, hopefully you used a similar type. In the attached pic is a 10-12ga version of the type of grounding ring I'm referring to. |
