12-17-2014, 12:05 AM | #1 |
Wiring harness routing
Where does the four wire taillight harness pass through the cab? Is it the firewall or the floor?? I can't remember..
///Relaxed Atmosphere |
12-17-2014, 12:08 AM | #2 |
Re: Wiring harness routing
Firewall, push in grommet on wiring should fit the hole
12-17-2014, 12:09 AM | #3 |
Cluster King
It will pass through the firewall above the transmission tunnel. I will see if I can find a photo and post it for you.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
12-17-2014, 12:13 AM | #4 | |
Cluster King
Hope this helps, Tom
12-17-2014, 12:19 AM | #5 |
I was just wondering the same thing. Glad you asked. I think I'll use the oil pressure or washer hole for mine, since I already covered the factory correct hole with my DBW pedal.
Currently wondering how everyone is running the front headlight wires up front. It looks like there is room to tuck it under the top lip of the core support. If I can cut a hole in the vertical braces, it will go from left to right without being seen. How is everyone running it inside the front fenders?
'68 C10 SWB '85 K30 Blazer |
12-17-2014, 09:18 AM | #6 |
Thanks for the info. I hope I didn't fill that hole. However, I think I can use the washer hole.
