Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 12-17-2014, 01:42 PM   #26
SDfarms
SDfarms's Avatar
Re: 72 chevy modern swap
I was curious if anyone could help me out on finding a 6 bolt pattern np205. I know they are like gold and everyone that has one wants to hold on to it. If anyone could help me out on finding one I would appreciate it. If not I will probably end up buying a advanced adapter kit #27-0030. Combining a 10 spline np205 to the 4500, but would like to avoid the adapter all together. Summit racing offers th advanced kit and its cheaper, thinking i will buy it threw summit and save 100 bucks.
SDfarms is offline   Reply With Quote
Old 12-17-2014, 03:33 PM   #27
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
This dude in CO named Ryanroo may have one or know of one. PM him and see if he can help you.
Ryan
1969 Chevy milk truck
Old 12-18-2014, 12:16 AM   #28
SDfarms
SDfarms's Avatar
Thanks Ill see what he says
Old 12-18-2014, 12:49 PM   #29
7dee2
7dee2's Avatar
Originally Posted by SDfarms View Post
The previous owner must have been quite the rigger using door hinges as exhaust holders,
Ha the hinged exhaust hangers made my day! I'm thinking it probably worked really well.
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 12-18-2014, 12:50 PM   #30
SDfarms
SDfarms's Avatar
Small modification to the frame, won't weld anything else in tell I no where the lines for the a/c are going. Got a good call yesterday, the specialty shop I work with called me and told me my engine would be here either this weekend or beginning of next week!
Old 12-18-2014, 12:51 PM   #31
SDfarms
SDfarms's Avatar
I was like wow when I got looking, three out of the four were hangers haha
Old 12-25-2014, 12:39 AM   #32
SDfarms
SDfarms's Avatar
Well I haven't posted in about a week. Went north with the old man ice fishing, but got back and went to pick up my present for myself! Its about damn time too.
Old 12-25-2014, 12:47 AM   #33
SDfarms
SDfarms's Avatar
Pulled the harness off, and the manifolds but was taking them off and two of the bolts were snapped off. I managed to spin the one out, but the other may be a challenge. You guys have any ideas????
Old 12-25-2014, 09:12 AM   #34
cmabolt
cmabolt's Avatar
1) Weld a smaller bolt to it. Heat the whole thing up and squirt wd40 on it. Back it out slowly with half turn in. Half turn out.
2) drill it out, use an easy out to extract the bolt. Heat works well here too.
3) trade for a motor without broken bolts.
Good luck and Merry Christmas
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636
Easier to beg forgiveness than ask permission!
cmabolt is offline   Reply With Quote
Old 12-25-2014, 11:24 AM   #35
SDfarms
SDfarms's Avatar
Chris
Worried about the aluminum going to heck. Made a couple phone calls last night, and we have a local machinist that told me he made a tool just for problems like the one I have.
Old 12-25-2014, 11:27 AM   #36
SDfarms
SDfarms's Avatar
The tree had a pretty damn good present under it with my name on it! Also order my advance adapter kit last night! Advanced even had a deal on them!
Old 12-25-2014, 12:37 PM   #37
ryanroo
ryanroo's Avatar
Chris
number one is my fave. i like to weld a nut to the busted bolt. a TIG welder really makes this easier. the heat from the welding does a great deal for breaking the corrosion that is holding the two together. the difference in heat expansion between the steel and aluminum helps in this case as well. anyhow, weld the nut and then twist it out while it is still warm. works well
number three is good too . or just replace with some l92 heads or something!
im diggin the column. i have been thinking about doing an aftermarket replacement as well
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 12-25-2014, 12:59 PM   #38
Maxxd07
Maxxd07's Avatar
Looks like a good project here, I like what your doing. Love the shop too! Merry Christmas and happy wrenching in the up coming year.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 12-26-2014, 09:27 AM   #39
SDfarms
SDfarms's Avatar
Ive tried that on a couple 350s but never worried me because of them being cast iron. Ill give it a shot on the 6.0 and let ya no how it goes
Also curious on standalone harnesses, I will probably end up running electric fans, I pretty sure the factory temp sense stays, but what about the oil pressure???
And if so I need to fine a piece for down by the oil filter because mine had a engine oil cooler on it, but i wont be using that.
Old 12-26-2014, 09:35 AM   #40
SDfarms
SDfarms's Avatar
Forgot the pictures!
Old 12-26-2014, 12:22 PM   #41
ryanroo
ryanroo's Avatar
there are a number of places that make block off or delete plates for the oil cooler ports. i think the GM number is 12577903
i dont know the secrets to the stand alone LSX stuff. if you want to use the OEM guage, you will just need to adapt a port into the oil galley for the OE spaghetti line that feeds the guage. if you are swapping to electronic guages, it will probably depend on if they interface with the computer or not. i am assuming the computer needs to see oil pressure to keep the fuel pump relay triggered, but that would depend on how you wired the fuel pump business too.
72 K20 12v build
Old 12-28-2014, 03:35 PM   #42
SDfarms
SDfarms's Avatar
I plan on keeping the original gauges in the truck, just was wondering if the computer needs to read the oil pressure.
Finally pulled the box off! and in the garage it goes.
Old 12-28-2014, 03:42 PM   #43
SDfarms
SDfarms's Avatar
My god is the back of the cab beat to hell. Looks like I will be doing a little more than I thought. The previous owner must have thought he was quite the rigger.
And does anyone need of a ford bumper?
Old 12-28-2014, 09:43 PM   #44
SDfarms
SDfarms's Avatar
Cleaned up the frame and pulled the rear cross member out too. It needed some work so got it fixed. Going to get the fuel cell in as soon as I can.
Old 12-28-2014, 09:58 PM   #45
SDfarms
SDfarms's Avatar
Had to cut and weld a new end on the 4wd shift handle so i could get my new b&m handle on.
I pulled my rear cover off and thought could it be a 10 bolt posi!?!?
Old 12-28-2014, 10:57 PM   #46
SDfarms
SDfarms's Avatar
Wondering if someone would be able to tell me if it is posi or not?
Old 12-29-2014, 06:05 AM   #47
swamp rat
swamp rat's Avatar
If it looks like this inside it is, Chevy called it a No Spin, but its really just a Detroit Locker. Look inside the little openings.
http://67-72chevytrucks.com/vboard/s...9&postcount=12
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-03-2015, 10:47 PM   #48
SDfarms
SDfarms's Avatar
Its an open carrier as well as the 14 bolt, oh well
Old 01-03-2015, 10:53 PM   #49
SDfarms
SDfarms's Avatar
Im selling both axles, They both have 4.10 gears.
Old 01-03-2015, 10:59 PM   #50
SDfarms
SDfarms's Avatar
Fabed up a behind the cab battery box. I want to clean up the engine bay so trying to get everything hidden and always wanted to put it behind the cab. Ill post the final product tomorrow.
