Old 11-12-2014, 06:26 PM   #26
gramps77
Re: Vent window assembly restoration??
Derek is who I worked with and did EXACTLY as he mentioned above. They didn't have anymore cores and I sent mine in and had them back in less than 2 weeks. Pretty fast if you think about it. Ship there, rebuild, and back.
ABSOLUTELY looked brand new.
gramps77 is offline   Reply With Quote
Old 11-13-2014, 08:26 PM   #27
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I just rebuilt mine the other day. It's really no problem. The nuts and bolts of it take maybe thirty minutes each. Any extra cosmetic refinish work you do above that will add whatever time.
I used the Precision brand seals and a rivet kit all from Classic Parts. I don't remember exactly but it seems like I had about 50-60 bucks invested in all of it.
The crux of it is that you remove 9 rivets per side, replace the rubber seals, and replace the rivets. The vendors sell a little rivet set tool for 4 dollars that you use along with their rivets to do the job. You just clamp the tool in your vise and peen the new rivets down with a hammer and punch. On a 1-10 difficulty scale it's about a 4.
I didn't take any completed pictures of them because there's really nothing to see. They look new, they don't leak, and the rubber is nice and supple.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-17-2014, 09:52 AM   #28
bluex
bluex's Avatar
I just found this write up as well. You'll have to copy an paste the link an remove the space between square an body...
http://www.gmsquare body.com/forum/showthread.php?t=5224
bluex is offline   Reply With Quote
Old 12-16-2014, 01:16 PM   #29
Chaplain
Chaplain's Avatar
Study material
Chaplain is offline   Reply With Quote
Old 12-16-2014, 02:26 PM   #30
ddr11
ddr11's Avatar
I just had mine done at a local glass shop for $40 each, I bought the new gaskets from lmc and the latches
ddr11 is offline   Reply With Quote
Old 12-17-2014, 03:49 PM   #31
MikeB
MikeB's Avatar
Originally Posted by J Knight View Post
With new vent window assemblies at $350+ per side, Im going to have to just restore mine. Has any one done this?
This summer I bought an entire passenger side assembly in great shape at a junkyard for $50, so look around. All my driver's side needed was a gasket and a latch, both readily available.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-17-2014, 04:58 PM   #32
J Knight
J Knight's Avatar
Right after I started this thread I found a NOS set for $400 shipped.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
